Euro r with pcd 5th gen prelude swap - Honda-Tech
Old 03-03-2017, 06:55 PM   #1
Default Euro r with pcd 5th gen prelude swap
Hey so recently I am having some confusion on how to use the pcd euro r ecu with the motor i5th gen usdm prelude. I understand everything I need to the dizzy and ckp tdc sensors and iacv. I am using the usdm harness with the euro r intake manifold. I have searched a lot and have not found what wires you need to cut and or repin in the rywire obd2a to obd2b jumper harness, I have tried following the diagrams but just get easily confused on locating wire and missing slots. What exactly do I need to repin or splice in the rywire jumper harness for the engine to run and throw no cels? Also is a special tool needed to repin? Thank you.
jmos707 is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
