DRL light
Old 01-26-2009, 10:17 PM
jomama3737's Avatar
Default DRL light
Hey I was looking at a write up about checking the code for the CEL and i was wondering if this same way could work on a DRL computer plug. If not how can i diagnose what is going on with my DRLs. They used to work and the light started to flicker. They havent worked in a while, but with them not working my brights dont work either. anyone have this problem too because its the only light left on my dash during the day and its getting annoying. thanks
Old 01-27-2009, 10:14 AM
Bender's lude's Avatar
Default Re: DRL light
same problem however i cant find the problem in mine either
Old 01-27-2009, 10:04 PM
danny_d19's Avatar
Probably a problem with the DRL relay. I had the exact same problem on my 95, the DRL light was always on and they did not work, and only 1 of the high beams worked (the DRLs are the high beams on lower voltage, so it makes sense).
I searched up a fix for the DRL relay, which is a fairly common problem, just need to resolder the relay. I did this to mine, and they worked flawlessly afterwards.
Old 01-28-2009, 08:09 AM
jomama3737's Avatar
Thanks I found the topic where u posted the DRL relay, I havent taken a look under the carpet yet, but resoldering the relay wires? or the relay, its just that part that im a bit confused about. or would a new realy do the same thing? thanks
Old 01-28-2009, 06:44 PM
danny_d19's Avatar
Here's the write-up I used: http://www.nyx.net/~smanley/hondadrlfix/
Buying a new one would fix it if the relay ends up being the problem.
Old 01-28-2009, 06:49 PM
jomama3737's Avatar
thanks i will take a look at that and get that light finally off my dash
Old 01-31-2009, 11:40 AM
so, that relay is above the pedals like it says on that website... i have heard different things from many people including my mechanic that all say other things...
Old 02-03-2009, 08:41 PM
danny_d19's Avatar
No the relay is under the passenger footwell carpet, beside the ECU
kcoons
Honda CR-V & Element
02-12-2014 03:27 AM
mussashimits
01-01-2007 09:55 AM
Quick Reply: DRL light
