Dome light wont come on when driver's door is opened (4th Gen) - Honda-Tech
Old 10-05-2005, 07:04 AM   #1
delguiner's Avatar
Default Dome light wont come on when driver's door is opened (4th Gen)
Hey guys, my dome light nor the open door light on my dash wont come on when the driver's side door opens. The passenger side door works perfectly. How do i check for that? Is there a fuse or something thats not making contact?
Thank you!
delguiner is offline   Reply With Quote
Old 10-05-2005, 07:26 AM   #2
Lewdin' Incognito's Avatar
Default Re: Dome light wont come on when driver's door is opened (delguiner)
There's a little black contact switch on the door frame that the door hits when it closes. If it's stuck in then the light won't come on. Probably not that simple, but it's a place to start.
Lewdin' Incognito is offline   Reply With Quote
Old 10-05-2005, 07:30 AM   #3
H22a T13's Avatar
This same thing happened to me, It wouildnt turn on with either door opened or by the switch. Untill yesterday when it magicly started to work.
H22a T13 is offline   Reply With Quote
Old 10-05-2005, 09:01 AM   #4
I just fixed mine the other day! I took the little slider switch off (it in the door jam) and the contacts were a little corroded like a battery terminal. I order to get the part out I...
1. unscrew the assembly with one phillips head screwdriver
2. unplug the connection after you pull out the switch
3. pull appart the slider switch, be careful not to lose the spring!
4.Clean the brass contacts with fine sandpaper or scotch brite.
5. reassemble in reverse order and let there be light!
eluder33 is offline   Reply With Quote
Old 10-05-2005, 09:14 AM   #5
VisPreludeVtec's Avatar
Default Re: Dome light wont come on when driver's door is opened (matty c)
mine is doing the same....will try this tonight thanks
VisPreludeVtec is offline   Reply With Quote
Old 10-05-2005, 09:19 AM   #6
Honda Sport's Avatar
cool, mine's was doing this also. will try tonight...
Honda Sport is offline   Reply With Quote
Old 10-05-2005, 09:21 AM   #7
mgags7's Avatar
haha
mines not doing it....
but good info matty boy
mgags7 is offline   Reply With Quote
Old 10-05-2005, 10:19 AM   #8
rawNArsxS's Avatar
mine was doin the same thing...i was actually starting to miss the anoying honda beeps that come on when the door is open lol...ill have to check this out too
rawNArsxS is offline   Reply With Quote
1996 Del Sol Vtec dome light??? Need help jc15025 Honda Civic / Del Sol (1992 - 2000) 1 09-09-2010 11:37 AM
Fried somthing? TravisCadello Honda Civic / Del Sol (1992 - 2000) 3 05-10-2009 06:34 PM
Dim Dome Light aalb1 Honda CRX / EF Civic (1988 - 1991) 1 03-26-2009 09:43 PM
Dome light doesn't come on when I open my door. Wilky Honda Civic / Del Sol (1992 - 2000) 16 01-24-2006 05:21 PM
dome light isn't working! Speed Ricer Honda Civic / Del Sol (1992 - 2000) 5 04-01-2003 07:26 AM
Tags
acura, dome, door, honda, light, lights, mdx, open, opend, opened, opens, switch, tl, tsx, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
