Does exhaust leak affect performance? - Honda-Tech
Old 02-26-2003, 09:05 PM   #1
ophdehEEzY
Guest
Posts: n/a
Default Does exhaust leak affect performance?
I have an Apex'i Dunk cat back. Would it affect my performance if I had multiple exhaust leaks. There is some kind of rattling around the stock header/downpipe around 3000rpm because it was custom done to fit my jdm h22 header to the h23 downpipe. Also, when I installed my catback, I never had the gaskets with it. TIA.
heezy
Old 02-26-2003, 09:11 PM   #2
KTeller8's Avatar
Default Re: Does exhaust leak affect performance? (ophdeheezy)
YES
your going to suffer from pressure lost and it does make some performance difference
also may make it even louder if the gasket isnt here or not sized right
[Modified by KTeller8, 11:11 PM 2/26/2003]
KTeller8 is offline   Reply With Quote
Old 02-27-2003, 01:25 AM   #3
ophdehEEzY
Guest
Posts: n/a
Default Re: Does exhaust leak affect performance? (KTeller8)
how big is the difference? is it noticeable? where CAN i get gaskets from? should i go through apex to get new exhaust gaskets or should i just go through a muffler shop or something?
Old 02-27-2003, 01:26 AM   #4
4bidden's Avatar
I have a huge leak right before my exhaust makes the S-bend. Maybe I'll try and fix that tomorrow.
4bidden is offline   Reply With Quote
Old 02-27-2003, 10:02 AM   #5
KTeller8's Avatar
yeah contact APEX-I
what size is it?
i might be able to get you one...
email me mkteller8@aol.com
Old 02-27-2003, 01:21 PM   #6
ophdehEEzY
Guest
Posts: n/a
[Modified by ophdeheezy, 1:21 PM 2/27/2003]
Old 02-27-2003, 02:37 PM   #7
roadawg's Avatar
it depends on the size of the hole in your exhaust. My brother had a leak in his exhaust on his civic and the car was a dog, i'm pretty sure it has something to do with back pressure. So he got it fixed and his power is restored.
roadawg is offline   Reply With Quote
Old 02-27-2003, 03:19 PM   #8
ophdehEEzY
Guest
Posts: n/a
Default Re: Does exhaust leak affect performance? (stealthmode)
would the stock exhaust gaskets work?
Old 02-27-2003, 09:58 PM   #9
h22jedi's Avatar
yea i got the saem problem i have a leak where the A pipe meets the B pipe on my dc 421 header. what should i do muffler shop, or call dc
h22jedi is offline   Reply With Quote
Old 02-27-2003, 10:42 PM   #10
KTeller8's Avatar
Default Re: Does exhaust leak affect performance? (h22jedi)
check with a muffler shop first
alot easier to deal with
dc might waste time or might not do anything. never know with the big boys
to the other guy. see if your stock gasket fits up. worth a try
Old 02-27-2003, 10:58 PM   #11
Quiklude's Avatar
yes, back pressure is a very needed thing with a n/a car, i dunno if it would be bad to the point of making it a "dog". but you might notice some difference, plus it sounds like shyt
Quiklude is offline   Reply With Quote
my valves are ticking pretty loud - will this affect engine performance? allums34 Honda Civic / Del Sol (1992 - 2000) 17 04-05-2011 05:52 PM
header air leak affect ref'd lilo_goki Honda Civic / Del Sol (1992 - 2000) 1 06-09-2008 01:06 AM
Will a dented downpipe really affect performance? pcguy760 Tech / Misc 16 04-21-2008 09:52 AM
Open Axle back or Open Header? BLK99VTECR Drag Racing 2 02-25-2005 09:42 PM
will exhaust leak affect AIR/FUEL ratio? JunIntegra Tech / Misc 5 12-24-2003 01:11 PM
Tags
affect, bad, big, car, effect, effects, engine, exhaust, h22, header, hole, leak, motor, motorcycle, performance, pipe, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
