DipStick shows no oil, No oil lights
Old 02-13-2005, 10:26 AM
951dc5's Avatar
Default DipStick shows no oil, No oil lights
93lude vtec; Rececently changed my oil about couple weeks ago, checked the dip stick where two dots are high and low. I took it out and it seems to have some oil layin around the stick and wiped it, put back into the hole and took it back out and the dry tip was never touched with oil. Even i let the car sit for hours after driving, it still shows no oil on the stick. The <U>oil lights</U> doesnt turn on. I thought it was empty and pour another 1 1/2 quart and it's still the same. Have this ever happen to anyone?
Old 02-13-2005, 10:34 AM
mgags7's Avatar
Sounds like you are low on oil, i would fill it up.....
The oil light is for low pressure, and i dont think you were low enough that the pickup wasnt fully submersed, so i think your ok. Just fill it and check it often.
Old 02-13-2005, 11:40 AM
951dc5's Avatar
Default Re: (mgags7)
yeah when i fill it up it would still be the same
Old 02-13-2005, 12:38 PM
95greenlude's Avatar
Default Re: (Prelude951)
go get a new dipstick.....it might not be going all the way down into the oilpan
Old 02-13-2005, 02:31 PM
fastfu's Avatar
Default Re: (95greenlude)
the dipstick cannot be wrong, you need to put more oil in
Old 02-13-2005, 02:32 PM
ludedude48's Avatar
i had some engine work done and the same problem...the dipsticks put the wrong dipstick in my motor.
BTW, do you have a JDM h22?
Old 02-13-2005, 05:10 PM
2point2's Avatar
sounds like you've been revving high lately..
Old 02-13-2005, 06:04 PM
mgags7's Avatar
if you accidentally switched dipsticks and didnt notice you are foolish....
if you get a shop to build your motor and they cant figure out what dipstick to put in you are foolish....
if you dont push the damn thing down the whole way to read it you are very foolish.....
Old 02-13-2005, 06:11 PM
Akhany's Avatar
Are you measuring your oil on a slope? If not parked on flat surface, do so.
I doubt this is the case, but, take out the dipstick housing and check to see that it isn't clogged up with muck. If there's enough crap in the dip stick housing, it could wipe the oil clean before you pull it all the way out.
Old 02-14-2005, 08:41 AM
951dc5's Avatar
Default Re: (Akhany)
the dip stick seems pretty correct for it's kind. I already have it park flat surface. When change oil and pour 5 quarts, it doesnt show full but just 1/4 of the dipstick.
Can this mean my oil are not circulating around and back into my oil pan?
Old 02-14-2005, 10:05 AM
EFz6er's Avatar
I would either go get a new dipstick or change the oil and check again when you know that there are 4-5 qts in there
Old 02-15-2005, 06:31 PM
951dc5's Avatar
Default Re: (EFz6er)
what can it possibly be? I changed oil with 5 new oil quarts and after a month later i checked the dipstick and it's all gone. I think i gotta sell this before it get worse.
highwhey
11-11-2010 05:53 AM
newyawkballa
Honda Civic (2001 - 2005)
11
02-15-2010 08:00 PM
sailor_55
11-04-2007 09:14 PM
linda02916
02-18-2005 09:45 AM
apexrift
11-21-2004 11:23 AM
Quick Reply: DipStick shows no oil, No oil lights
