Could a bad PCV valve cause you to fail an emissions test? - Honda-Tech
Old 10-08-2004, 06:00 AM   #1
Default Could a bad PCV valve cause you to fail an emissions test?
My car failed the emissions test and I noticed my PCV valve wasn't working so I replaced it and now it works. Would this have any effect on passing the test?
prelude9999 is offline   Reply With Quote
Old 10-08-2004, 07:55 AM   #2
Sephro's Avatar
Default Re: Could a bad PCV valve cause you to fail an emissions test? (prelude9999)
yes it could...
Sephro is offline   Reply With Quote
Old 10-08-2004, 08:23 AM   #3
AndyD's Avatar
Could a bad PCV cause major bogging issues??
AndyD is offline   Reply With Quote
Old 10-08-2004, 09:00 AM   #4
Default Re: Could a bad PCV valve cause you to fail an emissions test? (AndyD)
my pcv was bad and i didn't notice any bogging issues, seemed to run the same with and without it, i guess for $3 and 30 seconds you can't go wrong replacing it
Old 10-08-2004, 09:34 AM   #5
LugNutZ's Avatar
Yes, it can. If your running your car cap the vacum pull the valve and put a breather in. It will remove all those less explosive oil fumes from your intake. Every little bit helps when your trying squish your friends WRX.
LugNutZ is offline   Reply With Quote
1998 Honda Accord 4 cyl - Failed Emission Test (KOEO - Key On Engine On) jmj99f Honda Accord (1990 - 2002) 4 02-01-2013 02:20 PM
92 EX Failed Emissions test (NO ppm limit 467 my reading 1534) HELP!! MakoE2 Honda Accord (1990 - 2002) 12 03-28-2012 08:31 PM
B16a Smoking Randomly? slaquers Engine Management and Tuning 6 07-24-2011 11:14 AM
Question: PCV Valve on a JDM ITR Engine? Failing Emissions? 703_Sleeper Honda Civic / Del Sol (1992 - 2000) 10 03-16-2004 07:39 AM
pcv valve? what function does it serve ? MeanGreenEG9 Tech / Misc 18 04-05-2002 12:13 PM
Tags
240sx, bad, cb7, cel, emission, emissions, emmisions, fail, failed, failing, honda, pcv, prelude, pvc, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
