Could a bad alternator cause bogging or poor/insufficient spark? - Honda-Tech
Old 04-04-2005, 09:28 PM   #1
Keith's Avatar
Default Could a bad alternator cause bogging or poor/insufficient spark?
Question, could a bad alternator cause a poor/insufficient spark under half to full acceleration which results in bogging?
Keith
Keith is offline   Reply With Quote
Old 04-05-2005, 06:15 AM   #2
Keith's Avatar
Default Re: Could a bad alternator cause bogging or poor/insufficient spark? (Keith)
bump
Old 04-05-2005, 06:34 AM   #3
Old_Nocturnal's Avatar
I went thru a few alternators when my downpipe was cracked, and my car would run fine all the way down to between 10 and 9 volts on the turbo timer. All of the dash lights and headlights would go out before the car would quit running.
Old_Nocturnal is offline   Reply With Quote
Old 04-05-2005, 06:41 AM   #4
AndyD's Avatar
Hey Keith,
I had the same exact question for my 240SX. My battery light would light up a little too. I changed the alternator and it DID NOT fix the problem. My bogging is caused by another problem. If I get on the gas more than 25% of full throttle, the car bogs...bad.
On my Prelude, I accidently unplugged my alternator plug when i was adjusting my accessory belts. The car ran off the battery for 2 days. When the battery finally started to die, the car bogged pretty bad. But that only happened for less than a minute until the battery died. Before the battery died, the car ran fine.
At idle, if you try to rev up the car, does it bog then too?? I am trying to figure out my problem on my 240SX still. I think a few of the valves are bad because I've tried changing MANY different parts.
Anyway, if you need an alternator, let me know. I have one for sale. It's from a 4th Gen.
AndyD is offline   Reply With Quote
Old 04-05-2005, 10:41 AM   #5
Keith's Avatar
Default Re: Could a bad alternator cause bogging or poor/insufficient spark? (AndyD)
Thanks Andy, I already bought another alternator. I'm going to install it tonight.
Keith
Old 04-05-2005, 11:08 AM   #6
prelittlelude's Avatar
Quote:
Keith
let us know if it changes anything, but i have had a bad alternator cause bogging , but the battery was practically dead too,
prelittlelude is offline   Reply With Quote
Old 04-05-2005, 06:46 PM   #7
Keith's Avatar
Default Re: Could a bad alternator cause bogging or poor/insufficient spark? (prelittlelude)
Replaced the alternator... started her up and there was a bit of bogging at first... but I think it was the left over fuel (flooded) from the WOT test I was doing before on the bad alternator. So far so good
Keith
Old 04-05-2005, 10:43 PM   #8
PrettyLude's Avatar
Quote:
me two, but it was a bad battery
PrettyLude is offline   Reply With Quote
Accord bogging under normal acceleration - Problem AND Solution Draken Wolfe Honda Accord (1990 - 2002) 2 09-27-2013 04:05 AM
how to determine wether starter or alternator are bad elmejor Acura Integra 19 11-06-2008 08:12 AM
Problem: Code 92 flashing - Evaporative Emission Control System Insufficient venidero Acura Integra 2 03-05-2008 10:30 AM
EGR Flow Insufficient?? lax1089 Honda Accord (1990 - 2002) 20 03-28-2007 11:03 PM
b18b dying randomly, boggs bad/misfires acceleratin at low rpm... HELP!!! PLEASE!! turbotime Acura Integra 9 12-13-2006 09:40 AM
Tags
240sx, acceleration, alternator, bad, bogging, car, caused, die, full, honda, poor, prelude, proper, spark, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
