compression test #'s, NEED HELP!!!!!!
Old 06-17-2009, 11:56 AM
shooter93's Avatar
Default compression test #'s, NEED HELP!!!!!!
i have a 94 jdm h22a and i did a compression test and these are the number
cylinder #1 210psi
cylinder #2 210psi
cylinder #3 180psi
cylinder #4 180psi
Old 06-17-2009, 12:17 PM
ShoofIsLudin's Avatar
Default Re: compression test #'s, NEED HELP!!!!!!
my h22a has between 220-230psi in each cylinder.
Add a cap of oil to the low psi cylinders, and see if the numbers climb?
are you opening the throttle??
Old 06-17-2009, 12:21 PM
shooter93's Avatar
i jus tdid both 3 and 4 again and there at 210 psi.... and no i forgot about the wot part...let me go back and do them all ill report in about 15 min
Old 06-17-2009, 12:26 PM
shooter93's Avatar
ok at wide open throttle i got, 210, 215, 210, 225.... wtf is going on, i let it hit compression stroke 7 times each cylinder at wot
Old 06-17-2009, 12:28 PM
as long as they're within 10% of each other (20psi) it's normal.
Old 06-17-2009, 01:25 PM
Don Jefe's Avatar
Correct, it's not so much about the numbers themselves but the consistency of the numbers across the cylinders in general.
Old 06-17-2009, 04:01 PM
shooter93's Avatar
yeah well i did it again and got 235 in each one, tested each cylinder twice...
Old 06-17-2009, 05:24 PM
meanshyguy's Avatar
^^who's this moron? trying to be e-gangsta?
Old 06-18-2009, 08:51 AM
shooter93's Avatar
uhh your not talking about me are you? i'm pretty sure i'm just talking about a compression test? is that "e-gangsta"?
Old 07-17-2015, 12:39 PM
backinblue92's Avatar
your username, I would presume.
and I feel like you're doing it wrong dude. If your compression numbers are bouncing all around, then you need to unplug the main coil wire, and unplug the fuel pump fuse under the dash, top row, 15amp. #23 if memory serves.
Then crank it WOT doesn't matter how many cranks it takes (well it can for diagnosing but to keep it simple don't worry) just stop when it maxes out.
Those will be your final numbers. If anything comes up low, try a little oil, then retest. You shouldn't be getting different variances every time. Crank til it maxes out
Old 07-17-2015, 02:13 PM
TheJGB3's Avatar
way to bump a six year old thread
Old 07-17-2015, 04:29 PM
Lol. Idk how that happened. It showed up on my feed as new.
delsolo95
04-03-2013 08:49 AM
shooter93
06-17-2009 12:12 PM
aznxpyroboi
12-09-2007 10:09 PM
Tyteg
05-16-2007 07:30 AM
disboilikehoy
05-23-2004 05:41 PM
Quick Reply: compression test #'s, NEED HELP!!!!!!
