Clicking sound when stopping - Honda-Tech
Old 07-22-2004, 08:57 PM   #1
Supra's Avatar
Default Clicking sound when stopping
So, I was giving my buddy a ride today in my '94 prelude si to show him my new GPS system. The car has fairly new brakes and rotors. He brought up the clicking sound my car makes. When I apply the brakes the car makes this sound right before comming to a complete swap. He's built many different off road vehicles, so he is one to notice this sort of thing.
After putting some thought into it I seemed to recall that this car has made the that, "click" sound for awhile. At this point I am assuming I got acclamated to it and just did not let it bother me. Now I am kind of curious what it could be. I asked him if it could be the brake lines stretching. He seemed to think that would not be the case.
Supra is offline   Reply With Quote
Old 07-22-2004, 08:59 PM   #2
Hondaaccordvtec's Avatar
Default Re: Clicking sound when stopping (Supra)
Do you hear it coming from the front or rear of the car? Could be warped/out of round rotors causing the calipers to make the noise.
Hondaaccordvtec is offline   Reply With Quote
Old 07-22-2004, 09:04 PM   #3
Supra's Avatar
I would say pretty much for sure that it would be atleast the front. More then likely I'd have to have someone standing outside the car to hear if it also comes from the rear. My rotors/pads have about 4-6k miles in the front and 2-4k miles in the rear I would think. Maybe a little more then that in the rear.
Also, I should add that the sound is fairly loud and the car brakes fine. Previously when the rotors were worn the car would shake horribly when I went to stop. I know in my parents car the drums are, I think worn, and the braking does not feel right. I would think that would be the same with the rotors in my situtation.
Also, the braking ability of my car may have declined some. I am not sure, but I have thought to myself recently that it does not seem to stop quite as fast as it use to. Who knows if it is just my imagination or not. I can hear this clicking sound even with my stereo on.
Old 07-22-2004, 11:10 PM   #4
OTT
OTT's Avatar
Do you have grooved rotors? is so then the clicking noise you get on hard braking is the brake disk groove catching the leading edge of the brake pad. It is a common experience on grooved disks uder hard braking.
Some aftermarket manufacturers make calipers with two differen size pistons in order to stop the leading edge of the pad catching in this way.
If you do not have grooved rotors then you could possibly have an issue with the bearings in your inner CV sliding tripod joints on either side of the gearbox
OTT is offline   Reply With Quote
Old 07-23-2004, 07:32 AM   #5
Wiseguy619's Avatar
Default Re: (OTT)
Quote:
Ditto, jack your car up and look if you have torn CV boots.
Wiseguy619 is offline   Reply With Quote
Old 07-23-2004, 11:36 AM   #6
96PreludeSi+H22Head's Avatar
on my 96 there's some kind of metal flashing that act as a guard of some sort. well when mine was loose it caused that noise. could also happen if its bent.
96PreludeSi+H22Head is offline   Reply With Quote
94 EX wont turn over, good battery, no solenoid click and weird humming, etc...help! Popsgarage Honda Accord (1990 - 2002) 0 10-10-2015 08:36 PM
E brake adjustment help dc4teg95 Acura Integra 6 07-03-2010 10:39 AM
Problem with Manual transmission (I believe..) vipersvenom Honda Civic (2006 - 2015) 4 06-18-2008 11:21 AM
Clicking Sound When Braking dman81 Honda Accord (1990 - 2002) 6 10-06-2005 03:33 PM
Cliking-type noise coming from rear when braking moderately-hard. ntrinsik Honda Civic / Del Sol (1992 - 2000) 2 08-28-2003 07:38 PM
Tags
acura, applying, brakes, car, clicking, clicks, loud, make, makes, making, noise, pads, rapid, shake, sound, stop, stopping, ticking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
