o2 sensor wire replacement?
Old 05-19-2010, 12:55 AM
cfran55's Avatar
Default o2 sensor wire replacement?
hey guys i had a shop install my header and they had to rewire the o2 sensor wire that connects to the cat.
now the thing is after some time the wire started to get damaged and cut up from road debri. so im wondering if i could simple buy one of those o2 extension wire and simply replace the damaged wires?
i was thinking this extension kit from password jdm unless i can pick up an extension kit from pep boys autozone or advanced. im not sure if they even have such a thing there thoe.
http://passwordjdm.com/PasswordJDM-O...P1767C320.aspx
Old 05-19-2010, 06:06 AM
carnot's Avatar
Default Re: o2 sensor wire replacement?
Found one for a little cheaper from summit. I used this one to replace the plug when it got melted...
http://www.summitracing.com/parts/CEI-109200/
Old 05-19-2010, 04:23 PM
minilogoguy18's Avatar
Wish I knew about these about a year ago, but now working at the 'stealership' there's just tons of old harnesses laying around where I could just make one in my free time for nothing. =p
Old 05-19-2010, 09:26 PM
cfran55's Avatar
i mean would i be able to just swap this out with my wire now? its an extension i was wondering if i could use it to replace it
Old 05-20-2010, 03:44 AM
carnot's Avatar
You can use it to replace a section of damaged wire on the existing o2 sensor and electrical bung. Just cut the bad wire out, remove the female end from the extension, splice the new extension wire to the remaining wires coming from the o2 sensor. Observe good splicing practices when doing this...I would recommend solder and heat shrink wrap.
Old 05-20-2010, 11:25 AM
DCFIVER's Avatar
I wouldnt, since many O2 sensors of that era utilize the path of the wire itself to measure O2 content to compare to exhaust readings...
Old 05-20-2010, 04:13 PM
I hate fkin with solder, I just use butt connectors but cut the insulation off of them and shrink wrap over them, works very well.
crapanese
11-08-2006 09:57 AM
xgsrturbox
04-08-2006 11:01 PM
dropd4door
12-27-2004 10:22 PM
dropd4door
12-27-2004 09:53 PM
Quick Reply: o2 sensor wire replacement?
