check engine
1 Post
check engine
the other night me and my friend got done swaping a jdm dohc f22b into his 92 prelude si 4ws and we were just test driving it and went to the gas station and one the way back the cat back got disconnected from the cat and the car died and the check engine light went on then we started it back up and the check engine light was on and the car died again. has anyone ever had this problem before or knows what it might be????
also the car has a chipped ecu from a 91 accord ex with a jdm dohc f22b swap
Re: check engine (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">the exhaust fell off?!?!</TD></TR></TABLE>
.....too much....
.....too much....
Re: check engine (adam00)
yes. Id say its more a bad tps than your O2 system. Even if your cat fell off and tour the wires from the wire harness off, it would not send a signal to the ecu, and the ECU would run open loop as a saftey feature.
You having a chipped ECU might not be the case.
Only one way to find out. Put that exhaust back on and wire it back up.
1 Post
Re: check engine (Acidcrakker)
nothing happened to the o2 sensor the cat back got disconnected and nothing happened to the down pipe its still connected.
also the o2 sensor isn't on the cat its on the down pipe
1 Post
the cat go disconnected from the cat back nad it was real loud but nothing happened to the o2 sensor because its before the cat
1 Post
no but during the swap the plug that goes onto the tps cracked so you can slip it on and off the tps plug on the tps and i think it just came off i couldn't check it because it was at night i will check it tommorow also how do you check to see if the tps is good
Seedc2
07-23-2003 11:20 AM
