cheapest but best way to lower?
Re: cheapest but best way to lower? (EX-Boosted97Lude)
what is it.
lower what?
lower what?
cheapest is cuttin the springs but i would never do that, and highly recommend not doign that
other than that buy just lowering springs, which arent that much, and using stock shocks, but the ride uiality could suck real bad and blow the shocks out quick
Guest
Posts: n/a
Re: cheapest but best way to lower? (POSlude97)
i am assuming he means his car
damn it, i was think comression ratio, i swear i was... i am to much of an FI nut i guess
Re: cheapest but best way to lower? (FalconMan)
H&R Sport Springs 1.5 inch drop (About $135)
KYB AGX Shocks (Got mine on ebay for $70 a shock)
or you could go with KYB GR2 shocks (even cheaper I think $50 each from Tirerack.com)
KYB doesn't recommend going lower than 1.5 inches tho so... H&R sports were my choice, but if you want to go a tad lower go with the Eibach pros ($200 i think)
You could go cheaper and just get springs, but you'll prematurely wear out ur stock shocks (a few months maybe) Your call. I did lots of research before I chose my setup. Good luck.
[Modified by neoGTR22, 8:26 PM 4/1/2003]
Re: cheapest but best way to lower? (neoGTR22)
i just got my H&R sports and konis put in, it doesnt look like no 1.5 on my car though. i had to lower the front koni perch cause the back was lower now its slightly higher but not noticable......but it still didnt look all that lowered to me, what about you?
or you can go have your springs compressed and have spot welds made on each side of the springs
