Changing Fuel Pump
Re: Changing Fuel Pump (nsr_prelude)
Remove your back seat & rear center console as well as your rear liner from the trunk. Then, you'll see the metal plate w/a harness line feeding it. Unscrew the 5 philips screws to access the tank. Diconnect that harness from the pump feed top.
Unbolt the 6-10mm nuts (drivers side) & the fuel line. Be carefull not to lose any of the washers from the fuel line. From there you should be able to just lift out(w/some angled manuevering) the pump. When you reassemble everything, make sure the rubber gasket aroung the pump's opening is secure or you'll smell & spill an extra $4 of gas w/each launch/turn. Good luck!
ummm... i dont know about you, but i didnt have to remove my rear seats...... i installed a walbro 255 by just taking out the trunk lining.... you have 100 access to that place through the trunk in 4th gens.... not sure about 5ths....
