car shakes when sitting still
Old 01-21-2009, 10:13 PM
liquidflesh's Avatar
Default car shakes when sitting still
haven't been able to figure this out. when the car is running and in gear, it shakes like a champ. if it is in park, it doesn't shake, and when it is gear, when i let off the brake the second i push on the gas the shaking stops and it is smooth as anything.
thanks for the help
Old 01-22-2009, 05:35 AM
d15bdelsol's Avatar
Default Re: car shakes when sitting still
what's your rpm when its shaking?
Old 01-22-2009, 10:13 AM
gstrudler's Avatar
i'll put my money on a low idle, was just discussed in another thread.
Old 01-22-2009, 10:23 AM
badboyr66's Avatar
Yeah sounds like a nasty running motor. I would suggest a tune up... set your timing... maybe a timing belt time. Give us a little more info since there are a few things it could be
Old 01-22-2009, 04:36 PM
i'll have to get back to you on the idle part cause the starter just went out, ill have that fixed fri, but i had the bouncy idle prob and i fixed that, i'm pretty sure the idle is fine.
thanks
Old 01-22-2009, 07:11 PM
G2IntegraGS's Avatar
What year is the car? Im just curious b/c it seems like your having alot of trouble with it.
Old 01-25-2009, 02:03 PM
i got the starter fixed. as most of you know the bottom bolt on the starter is kinda of a pain, well whoever changed the starter before me decided not to tighten it...so it being loose i guess is what caused the mount to break. anyways, it is a 92 with 218k. ALOT i know but it really runs great minus the shaky prob, no leaks, good mpg.
the rpms are at the 1st mark below 1k, when i am sitting stopped. Not sure what that # is but that is where it is. i have also noticed that it doesn't do as bad in revearse and in drive. if drive was 100% shaking then revearse would be 25%. and in N and P it goes away.
thanks again guys
Old 01-25-2009, 02:09 PM
jrzy2nR's Avatar
suggest getting your timing done and adjust your valves
Nolenrob7
18
04-04-2017 03:30 PM
drumking15
07-24-2007 10:00 AM
Fullthrottlegsr
07-16-2004 09:05 PM
preluder
07-25-2003 11:57 AM
lude97dude
07-23-2003 02:27 PM
Quick Reply: car shakes when sitting still
