Car shakes or shudders on clutch engagement - Honda-Tech
Old 12-02-2011, 05:07 PM   #1
Default Car shakes or shudders on clutch engagement
the lude shakes or shudders very hard before clutch engages, all motor mounts are good... this a new clutch with approx 100 miles, it was fine until a few days ago, once the clutch engages and gear shifts everything's its good, the shake only happens on low rpm engagement, when i rev up to about 4k to 5k to take off it the car doesn't shake... its a stage 4 xtd clutch kit (un-sprung disc) and used fidanza flywheel with new friction surface, if your going to come bash on the product don't waist your time on this thread, thanks in advance...
blkbb6 is offline   Reply With Quote
Old 12-02-2011, 06:17 PM   #2
Default Re: Car shakes or shudders on clutch engagement
bump!
Old 12-02-2011, 07:03 PM   #3
Enzo15's Avatar
With an unsprung clutch there is no feathering of the clutch in... It will kill the clutch. Those type of clutches are basically drop and go. Not meant for comfort or ease of use.
Enzo15 is offline   Reply With Quote
Old 12-07-2011, 03:51 PM   #4
I think its normal for the set up you have to shake at low RPMs. I have a clutch masters stage 4 and it does the same ****. Basically when you shift at a low rpm its going to vibrate. I hope you have a turbo set up, or running atleast enough power for it.
5thgencoop760 is offline   Reply With Quote
Old 12-07-2011, 04:07 PM   #5
Honda owns me
typemismatch's Avatar
Even my sprung 6-puck shudders at low RPM, backing out of my driveway is a bit of a chore ... this could be because the springs aren't fully broke in though too.
These clutches are intended to be dumped in the burnout box and at the starting line, not DD'd. If you insist on using one, get used to it.
typemismatch is offline   Reply With Quote
Old 12-08-2011, 05:39 AM   #6
my buddy had a mustang and replaced the clutch but didn't get the flywheel resurfaced, and every time he put the clutch in the entire car would shake.
if it is a new or resurfaced flywheel then its probably from having the upgraded clutch
vtec_ftw is offline   Reply With Quote
B18C EJ8 Clutch shudders when cold. mixx2001 Honda Civic / Del Sol (1992 - 2000) 16 03-07-2013 06:54 AM
Clutch shudders Shoobie Acura Integra 1 08-30-2007 05:49 PM
tranny shudders mattymatt Acura Integra 5 10-03-2002 09:38 PM
Clutch shudders when engaging Malgerus Honda CRX / EF Civic (1988 - 1991) 6 08-31-2002 09:38 PM
Clutch shudders when being engaged... normal? BensGSR Acura Integra 5 02-06-2002 06:32 PM
Tags
2005, car, civic, clutch, engagement, honda, low, makes, performance, problems, rpm, shake, shakes, shaking, shudders, shutters
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
