Cant start this car
Cant start this car
i have a 90 honda prelude si. i have been trying to start this car for a while now. replaced fuel pump, filter, and fuel pump relay. i have fuel going to the front to fuel filter thru the injectors. i have spark from coil to cap and rotor, the spark to plugs.. new plugs also still nothing.. I'm in need of any ideas to help me turn this car on i really am digging the car just need it to turn on..
Re: Cant start this car
Yes it does, if you are getting an orange spark usually means a weak spark. Bright blue is a good healthy spark. If you are getting good spark I would look to see what the fuel looks like coming out of the injectors. A nice cone shape is good. If it dribbles or something usually would mean they have some gunk in them or they need rebuilt/replaced.
Also you may check the compression on the cylinders.
the spark is blue on the plugs and i haven't checked the codes I'm gonna try that thanks. what do you think about the camshaft sensor? can that also be a problem?
I dont believe your Prelude has a cam sensor. It should have a crankshaft sensor but I would think if they was bad the car would at least back fire or act like it wanted to start. Heck wouldnt hurt to maybe buy a different ecu and hook it up and see if it run. They run about 40 bucks used.
dth0ng69
10-10-2010 08:26 PM
1997 PRELUDE Auto Trans. NOT starting after 12+ hours of sitting. Got spark, got fuel on 3 plugs Ple
Johnny916
08-07-2005 05:45 PM
