Cam gears install....
space cadet
Re: Cam gears install.... (whiteinteg95)
what do you want a full write up of how to do it?
may i suggest a helms manual. i do not have a write up of how to do it.
Re: Cam gears install.... (Tru_Playah)
Is this the same on a b-series engine? Ive read the site that Tru_playah added http://www.hondaprelude.to/install_camgears.html, it says nothing about removing the valvecover, i thought you had to. Please correct me if im wrong.
space cadet
1.Remove the negative battery cable first.
2.Remove the valve cover. You need to remove both hoses from the cover and the ground wire thats bolted to the side. Remove the two cables on the alternator that run up over the engine and remove the spark plug wire cover and the plug wires. Once this is done and the valve cover bolts removed you should be able to lift the cover off. Make sure the gasket goes with it. Cover the open head so nothing gets in it while you work.
3.Remove the middle timing belt cover by removing the two 10mm bolts that hold it on. You may need to work at this thing a bit to get it out.
4.Set the cam gears to TDC (Top Dead Centre).
ummm.. step 2.
ummm.. step 2.
