Cam Gear weight: AEM vs. Skunk2 - Honda-Tech
Old 12-10-2002, 11:25 PM   #1
satan_srv's Avatar
Default Cam Gear weight: AEM vs. Skunk2
For inquiring minds that want to know, Skunk2 cam gears are lighter than AEM cam gears.
I have both of them right here the AEM is defintely heavier. You can pretty much already tell because the skunk2 a smaller internal piece, but anyways it's lighter so I expect it spins better freeing up hp!
Every little bit helps
[Modified by satan_srv, 2:25 AM 12/11/2002]
satan_srv is offline   Reply With Quote
Old 12-11-2002, 11:21 AM   #2
KGAccord's Avatar
Default Re: Cam Gear weight: AEM vs. Skunk2 (satan_srv)
Skunk2 cam gears are really nice especially when you consider they can be had for under $200 shipped if you look around. I doubt you'll notice a difference from the weight though even with oem cam gears.
KGAccord is offline   Reply With Quote
Old 12-11-2002, 11:46 AM   #3
DsITR's Avatar
like the man said..
it's the same concept as lightweight wheels...rotating mass has a big impact when you consider weight.
DsITR is offline   Reply With Quote
Old 12-11-2002, 11:56 AM   #4
satan_srv's Avatar
Default Re: Cam Gear weight: AEM vs. Skunk2 (dsludefosho)
I'm gonna guess the stock gears are even heavier....I was surprised at the difference between the AEM and Skunk2...
Skunk2 gears plus my super strong belt = one badass rotating assembly!
Old 12-11-2002, 05:03 PM   #5
Tb Fivel's Avatar
just out of curiosity....what belt are you running satan?....ive only heard of one belt for an h series motor besides the oem belt....and im curious to hear if you have any -/+ feedback on it. thanks
Tb Fivel is offline   Reply With Quote
Old 12-11-2002, 06:42 PM   #6
EH2DX's Avatar
i got SKUNK2 cam gears on my car. just installed them last week. i have to tune them though...
do you guys have clearance issues? mine rub somewhere making this whistle-like sound. people think i have a supercharger... i removed the top cover, but from what i hear i need to remove the bottom one as well. is this true? if so, i got a project to do this weekend.
EH2DX is offline   Reply With Quote
Old 12-11-2002, 07:33 PM   #7
satan_srv's Avatar
Default Re: Cam Gear weight: AEM vs. Skunk2 (Tb Fivel)
Power Enterprise....when the motor goes back together...
Old 12-11-2002, 07:36 PM   #8
satan_srv's Avatar
Mine won't rub! THese are the old AEMs....
Old 12-11-2002, 07:51 PM   #9
fastludeh22's Avatar
the skunk 2's are still lighter then the new aem ones. my girl has aem, i have skunk 2.
to the guy who was rubbing, did you take the cover between the cam gears and the head off?
fastludeh22 is offline   Reply With Quote
Old 12-11-2002, 08:41 PM   #10
smslude's Avatar
While we are on the subject of cam gears, i was thinking of getting some AEM's but one of my friends told me that they can do more harm than good on your engine by decreasing the engine life is this true?
smslude is offline   Reply With Quote
Old 12-11-2002, 11:07 PM   #11
EH2DX's Avatar
Default Re: Cam Gear weight: AEM vs. Skunk2 (fastludeh22)
no, like i said, that's my project for this weekend. it does sound kinda sc-like and i want to get rid of that sound...
Old 12-11-2002, 11:40 PM   #12
Default Re: Cam Gear weight: AEM vs. Skunk2 (BB1)
oh, when you said bottom, i was thinking lower, as in the one near the crank pully. if i was you, i would just cut the one behind the gears off. screw taking the timing belt off to get that out.
Old 12-12-2002, 12:06 AM   #13
Im ordering some cam gears for my F22A1 here shortly...
I think ill go skunk2...
but really how much HP will you gain?
dustywebber is offline   Reply With Quote
Old 12-12-2002, 01:02 AM   #14
EH2DX's Avatar
actually i have to change the timing belt anyway so it doesn't matter. it will be a fun project.
Old 12-12-2002, 06:28 AM   #15
used to run skunk2's on my h22a about 2 years ago. i personally didn't like the the actual quality of the gears.
str used to have the best ones in my opinion.
bgod is offline   Reply With Quote
Old 12-12-2002, 06:51 AM   #16
satan_srv's Avatar
Default Re: Cam Gear weight: AEM vs. Skunk2 (dustywebber)
I really doubt you will have any gains with cam gears on an F22A1, especially with stock cams. Sorry to keep shooting down the F22A. I suppose you could prove me wrong..
Old 12-12-2002, 08:06 AM   #17
Ive always heard horror stories about the AEM cam gear because it only has 3 bolts and can slip, whereas the skunk2 cam gear has 6 i believe.
dvp95 is offline   Reply With Quote
Old 12-12-2002, 09:02 AM   #18
OG triple OG
ATS*Mark's Avatar
Default Re: Cam Gear weight: AEM vs. Skunk2 (dvp95)
aem cam gears suck *****
ATS*Mark is offline   Reply With Quote
Old 10-06-2003, 01:44 AM   #19
Ruffryde009's Avatar
Default Re: Cam Gear weight: AEM vs. Skunk2 (TURSpoonEK)
whats the installation cost on cam gears (average?)
Ruffryde009 is offline   Reply With Quote
Old 10-06-2003, 05:02 AM   #20
satan_srv's Avatar
Default Re: Cam Gear weight: AEM vs. Skunk2 (preludeprojex)
Quote:
whoa old school post. Usually cam gears are installed with new cams, so whatever a cam install costs cam gears are usually included.
Old 10-06-2003, 05:28 AM   #21
martha's Avatar
Did you actually put the cam gears one a scale. Just curious of numbers.
martha is offline   Reply With Quote
Old 10-06-2003, 07:04 AM   #22
silver97prelude's Avatar
anyone use the STR cam gears?
silver97prelude is offline   Reply With Quote
Old 10-06-2003, 03:09 PM   #23
19924ws's Avatar
http://www.jgenginedynamics.com/CAM%20GEARS
JG 249 grams
Modified by 19924ws at 12:59 AM 10/7/2003
19924ws is offline   Reply With Quote
Old 10-06-2003, 03:23 PM   #24
Default Re: (19924ws)
I had 3 to compare... the h22a skunk2 i had were extremly lighter than aem... also to fit the new style skunk2 you need to grind the plastic part of the cover.. (the half moon to clear, because the bolt is exactly the lenght needed to fit.. so when you clear the spacing you actually go through the plastic.. here is a pic to compare..
look at the plastic cover...
this is my h22a built motor for my ek, mind you the headers different,so is the intake and other things
More PoWA!
ahhaah
HotWheelz is offline   Reply With Quote
Old 10-06-2003, 03:28 PM   #25
noble4ws's Avatar
why did you put those breathers on your valve cover and intake
noble4ws is offline   Reply With Quote
FS: Prelude VTEC Calipers satan_srv For Sale 6 03-08-2005 11:32 PM
Best H22a valves satan_srv Honda Prelude 20 12-10-2002 11:26 PM
CKF sensor voltage? satan_srv Acura Integra Type-R 2 12-05-2002 06:12 PM
Straight Pipe at the flick of a switch satan_srv Honda Prelude 19 11-28-2002 11:51 PM
Accord Type-R valves satan_srv Honda Prelude 12 11-23-2002 11:30 PM
Tags
94, aem, beltonebadassyahoocom, cam, camgears, gear, gears, god, h22, skunk, skunk2, supra, toda, weigh, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
