Brake Lamp Problem! HELP!
issue: my brake lamp light is on. all my brake lamps work, except one -rear passenger side. the bulb however is still good, because the parking lights still work.
Re: Brake Lamp Problem! HELP! (94Vtecluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder »</TD></TR><TR><TD CLASS="quote">If it's a gen 4 it's a dual filament blub which means even if it comes on with your parking lights it could still be blown.</TD></TR></TABLE>
correct...replace that bulb.
On another note...When I start my car I can turn on every light on my car and that brake lamp will stay off. But the very second that I tap the brakes...That DAMN brake lamp light comes on and stays on until I turn the car back off and restart.
Any Ideas on that?
Any Ideas on that?
Re: Brake Lamp Problem! HELP! (WhiteBB2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteBB2 »</TD></TR><TR><TD CLASS="quote">correct...replace that bulb.
Any Ideas on that?
Eh...make your own thread.
The bulb is still good because I switched that bulb out w/ the "working bulb" from the driver side -still no luck. Bump for more help or a wiring diagram.
Modified by LOC714 at 8:20 PM 11/29/2006
Any Ideas on that?
Make sure your bulbs are the same. I blew 2 bulbs because my drivers side was different. (previous owner.. =[) It worked fine on the driver's side, but messed up the balance and blew the p/s. I since then replaced both and it now works just fine.
Re: Brake Lamp Problem! HELP! (LOC714)
Doesn't the brake lamp come on if you're low on brake fluid? Might want to give that a check...
EDIT: - oh, but you said one light isn't working. Take a small wire brush to the contact and check the wire if you are absolutley sure the bulb itself is still good.
Re: Brake Lamp Problem! HELP! (Lewdin' Incognito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewdin’ Incognito »</TD></TR><TR><TD CLASS="quote">Doesn't the brake lamp come on if you're low on brake fluid? Might want to give that a check...
EDIT: - oh, but you said one light isn't working. Take a small wire brush to the contact and check the wire if you are absolutley sure the bulb itself is still good.</TD></TR></TABLE>
tried the wire brush w/ some electric lubie, no dice...any other advice? -because i just got a fix it!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LOC714 »</TD></TR><TR><TD CLASS="quote">issue: my brake lamp light is on. all my brake lamps work, except one -rear passenger side. the bulb however is still good, because the parking lights still work. </TD></TR></TABLE>
mine goes out sometimes, just hit the taillight like fonzie
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder »</TD></TR><TR><TD CLASS="quote">If it's a gen 4 it's a dual filament blub which means even if it comes on with your parking lights it could still be blown.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteBB2 »</TD></TR><TR><TD CLASS="quote">correct...replace that bulb.
Any Ideas on that?
you guys are right. it was the bulb, a simple problem.
Any Ideas on that?
nicolaselias
12-22-2011 03:58 PM
