blower motor removal - Honda-Tech
Old 10-05-2005, 05:49 PM   #1
sexyblack93lude's Avatar
Default blower motor removal
my heating blower motor is shot in my prelude and i need to put a new one in. whats the easiest way to removal just pretty much remove everything in it way? if any one has a rwrite up on this or any helpful tips about removing or intstalling that would be great thanks
sexyblack93lude is offline   Reply With Quote
Old 10-06-2005, 09:45 AM   #2
Default Re: blower motor removal (sexyblack93lude)
bump
Old 10-06-2005, 10:41 AM   #3
Hawkze_2.3's Avatar
Eh, just take the glovebox and stuff out and you should be able to get to it. Some bolts are harder than others, but you can get it if you look around in there for a bit.
Hawkze_2.3 is offline   Reply With Quote
Old 10-07-2005, 01:06 PM   #4
Default Re: blower motor removal (Hawkze_2.3)
bump
Old 10-07-2005, 01:58 PM   #5
tdo
your going to have to take out your whole dash. Then take out the blower motor. If you need one let me know i have one that ill let go cheap. im parting my prelude out see my sig.
tdo is offline   Reply With Quote
Old 10-08-2005, 11:27 AM   #6
fastlude69's Avatar
i just unscrewed the three bolts holding it in and dropped it out but thats just me. lol
fastlude69 is offline   Reply With Quote
Old 10-08-2005, 11:41 AM   #7
Default Re: (fastlude69)
out of what kind of car?
Old 10-08-2005, 11:42 AM   #8
Default Re: (sexyblack93lude)
92-96 lude?
Old 10-08-2005, 11:44 AM   #9
yeah i need a blower motor how much?
Old 10-08-2005, 11:50 AM   #10
fastlude69's Avatar
yea mine got cloged with stuff form the inside of the car from when it went on recirculate. so i went under the pass side and there where three screws holding it in and it droped out. i had to move the kick plate for the ecu to get it all the way out. then i stuck a vacumm in it to clean out all the stuff then stuck it back in and my heater blower worked again. didn't remove the dash or anything cuz i just did it the way it said in the manuel.
Old 10-08-2005, 11:58 AM   #11
fastlude69's Avatar
this is what it looks like it was clogged up with liek lint and stuff which prevented it from moving
Old 10-08-2005, 01:36 PM   #12
tdo
Quote:
its from a 92-96 prelude. and give me an offer.
Old 10-09-2005, 12:40 PM   #13
Default Re: (tdo)
im gonna try to clean it then ill let u know if i need it
Old 03-14-2017, 02:41 PM   #14
How do u get the the final screw in the way back to get the blower motor out I got two can't get the one against the wall
Kmeade94 is offline   Reply With Quote
Old 03-14-2017, 10:14 PM   #15
You may need a ratchet with a screwdriver bit.
holmesnmanny is online now   Reply With Quote
1990-1993 Accord Blower Motor Assembly / Resistor Removal and Replacement NOFX Honda Accord (1990 - 2002) 22 08-19-2016 08:42 PM
How to access 2010 Accord EX blower? webgrunt Honda Accord & Crosstour (2003 - Current) 4 07-06-2014 11:25 AM
CRV blower motor resistor reallycooleg Honda Element & CR-V 6 06-25-2010 03:18 PM
blower switch help! XkjeldorX Acura Integra 7 08-28-2006 09:01 AM
AC Blower install on a 4th gen -- pos w/o dropping the whole unit? datac99 Honda Prelude 5 04-19-2004 12:13 PM
Tags
1991, 2002, 91, 93, blower, civic, crv, heater, honda, howto, integra, location, motor, prelude, removal, remove, removing, taking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
