best vtec oil?
Old 04-09-2006, 03:37 AM
darkstar1440's Avatar
Default best vtec oil?
Does anyone know what the best oil woiuld be to run on my 130000 mile h22a1 is royal purple and good ??please help what's good?
Old 04-09-2006, 05:07 AM
PRELUDE-GT35R's Avatar
Default Re: best vtec oil? (darkstar1440)
As long as you change every 2000 mlies. Its all good for your motor
Old 04-09-2006, 08:21 AM
mkazm83's Avatar
RP, Mobil 1, Amsoil, are all good oils.
Old 04-09-2006, 08:46 AM
93h22a1vtec's Avatar
Default Re: best vtec oil? (mkazm83)
mobil 1 ftw
Old 04-09-2006, 10:25 AM
Buffalo's Avatar
Default Re: best vtec oil? (93h22a1vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93h22a1vtec &raquo;</TD></TR><TR><TD CLASS="quote">mobil 1 ftw</TD></TR></TABLE>
x2
Old 04-09-2006, 10:29 AM
M2B4's Avatar
Default Re: best vtec oil? (Buffalo)
royal purple FTW
Old 04-09-2006, 10:31 AM
honda3431's Avatar
mobil 1 synthetic. and change it every 3-4k. and use the Honda S2000 oil filter. make sure you change the washer.
Old 04-09-2006, 10:33 AM
M2B4's Avatar
Default Re: best vtec oil? (honda3431)
what makes the honda s2000 filter so much better?
Old 04-09-2006, 11:56 AM
DIRTYsouthBB6's Avatar
Default Re: best vtec oil? (M2B4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 &raquo;</TD></TR><TR><TD CLASS="quote">what makes the honda s2000 filter so much better?</TD></TR></TABLE>
It's JDM boooiiiiiii!!!!!!!!!
Old 04-09-2006, 11:59 AM
Yield's Avatar
There is no reason to change your oil anywhere near 2-3000 miles. You're wasting your money. Synthetics last much longer - in the 5-10,000 mile range. Do an oil analysis if you don't believe it. Just get a good synthetic like mobil 1 or the german castrol.
Old 04-09-2006, 01:37 PM
honda3431's Avatar
It's not made by Fram and its OEM
Old 04-09-2006, 01:38 PM
honda3431's Avatar
Default Re: best vtec oil? (DIRTYsouthBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRTYsouthBB6 &raquo;</TD></TR><TR><TD CLASS="quote">
It's JDM boooiiiiiii!!!!!!!!! </TD></TR></TABLE>
You're a *** and have no idea what you're talking about
Old 04-09-2006, 02:17 PM
redtop22's Avatar
Old 04-09-2006, 02:24 PM
BlueLude 94's Avatar
Default Re: (redtop22)
Greedy just released an oil that is strictly ment for VTEC engines.
Old 04-09-2006, 02:42 PM
Default Re: (BlueLude 94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueLude 94 &raquo;</TD></TR><TR><TD CLASS="quote">Greedy just released an oil that is strictly ment for VTEC engines.</TD></TR></TABLE>
any more info on that?
Old 04-09-2006, 03:20 PM
mkazm83's Avatar
HAHAHA.
Old 04-09-2006, 03:31 PM
moderator emeritus
98vtec's Avatar
Default Re: (mkazm83)
Royal Purple here
Old 04-09-2006, 04:07 PM
lewdlude's Avatar
Royal Purple here. Call me obsessive but i change my oil every 2500-3500miles with partial quart top offs. h22's are notorious for oil consumption. Valve seals, and cam seals will help. But even from the factory they burn oil. I say check your oil regularly, make sure you're lubricated, top off as needed, and at least change at the recommended interval 3750miles unless you run synthetic then as yield said 5-10kmi. Measuring how much oil is left in your engine between intervals will give you a better idea of how much oil your motor burns or leaks (that's beyond the scope of this discussion). I have seen approx 1qt per 1000mi, of consumption, with conventional oil and half that for royal purple at least on my vehicle. So i think top offs are especially important.
Send some samples to blackstone for analysis. Let a professional determine how long you have before changing your oil.
Old 04-09-2006, 04:09 PM
moderator emeritus
98vtec's Avatar
Default Re: best vtec oil? (lewdlude)
i change mine every ~4500
2500 is way to earlier.....thats just getting into the oils peak.
Old 04-09-2006, 05:30 PM
honda3431's Avatar
Default Re: best vtec oil? (98vtec)
after i pass 3k, i start thinking about changing it. sometimes i keep it in there until over 4k. but i use synthetic. contrare to what some may say, synthetic does break down if you run your engine hard. i was burning a quart every two weeks before i changed my oil last. and that was after about 4,500 miles.
Old 04-09-2006, 05:33 PM
AnthonyG2003
Guest
Posts: n/a
i heard about that as well....
Old 04-09-2006, 06:14 PM
M2B4's Avatar
Default Re: best vtec oil? (AnthonyG2003)
ive learned to let everyone else test new stuff then try it
Old 04-09-2006, 06:17 PM
bad-monkey's Avatar
i change oil every 8000 miles.
mobil 1 10w30.
i refuse to change oil every 3000 miles.
og poster: what kind of oil have you been using for the past 130000 miles? synthetic in a high mileage motor can lead to some headaches.
Old 04-09-2006, 06:30 PM
M2B4's Avatar
Default Re: (bad-monkey)
im gunna be running royal purple 5w-30 plan to change every 5k
Old 04-09-2006, 06:53 PM
monalisa overdrive's Avatar
I've been running Amsoil Series 2000 0W-30 for about 10k, runs well
Quick Reply: best vtec oil?
