best compression to turbo
what is the best compression to turbo. turbo person from over here said if you turbo a high compression motor you will make more power than a low compression motor runinng the same amount of boost
Re: best compression to turbo (RGSH22ACCORD)
9.0-9.5:1 compression is the best. still can run high boost, and still have some power when not in boost. also the motor doesnt detonate with the CR. you can also run about 10:1 CR but a really good tune is required for that.
and what the other guy said yeah its also in the tuning to.
the higher the compression, the easier your motor will denotate. which is very bad news...
just dont overdo anything, compression/psi. and yes of course good tuning also helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGSH22ACCORD »</TD></TR><TR><TD CLASS="quote">what is the best compression to turbo. turbo person from over here said if you turbo a high compression motor you will make more power than a low compression motor runinng the same amount of boost </TD></TR></TABLE>
I would say 9:1 would be ideal.
TehMoonRulz
05-16-2005 01:15 PM
s0liDyNe
07-19-2003 10:24 PM
