spark plug wires
Old 11-05-2013, 04:25 PM
powerpuff's Avatar
Default spark plug wires
In comparison to NGK is boch any good ?
Old 11-05-2013, 07:22 PM
motoxxxman's Avatar
Default Re: spark plug wires
no. in comparison to NGK, nothing is any good. seriously.
and bosch is about the worst, I have yet to find a single set of bosch wires that work decent in any vehicle, let alone a honda
Old 11-05-2013, 07:56 PM
powerpuff's Avatar
Thanks thats good to know cuz i was gonna buy a set of boch 30 min ago but decided to wait
Old 11-05-2013, 09:33 PM
AudioFunk's Avatar
I needed new wires asap and got bosch ones and havent had a problem yet. I want to get some ngk ones though
Old 11-05-2013, 09:53 PM
holmesnmanny's Avatar
Bosch might work for a little while but at some point they might start popping off like has happened to other people.
Old 11-06-2013, 05:42 AM
motoxxxman's Avatar
bosch wires frequently arc right out of the box. the biggest issue I've found with bosch wires though is the terminals tear off very easily, making it near impossible to remove and reinstall them without having to replace them. and with Hondas, the wires have to be removed and reinstalled somewhat often compared to other vehicles for several of the standard maintenance things.
NGK wires never arc, and never tear
Old 11-06-2013, 04:12 PM
powerpuff's Avatar
Also what kind of spark plugs should i use the ngk platnum or the ngk copper ones?
Old 11-07-2013, 07:36 AM
acedude180's Avatar
NGK iridium ftw w blue NGK no bs 10.2 mm wires. Go with Japanese parts like the factory did. If u r turbo go a little colder
Old 11-07-2013, 02:22 PM
minilogoguy18's Avatar
No aftermarket plug wire will outperform an OEM one.
Working at the dealer I've seen cars from the mid to late 90's come in with the original factory wires and after being curious and doing a resistance test on some, they're still good after 15 years.
All it takes is a simple resistance test.
The only thing really better than the stock ignition system is coil on plug and that's only because you don't have to replace worn out rotors and caps, reliability is better with COP. A bad ignition coil on newer cars is VERY rare.
Same with plugs, unless you've drastically altered the engine the plugs recommended in the FSM will always do the job, no matter how hard you drive the car.
I actually see more misfires on older cars caused simply because someone thought they knew better than the engineers who designed the car and put some blue colored wires on there.
Old 11-07-2013, 05:17 PM
powerpuff's Avatar
Thanks thats all I needed to know
Old 11-10-2013, 09:29 AM
motoxxxman's Avatar
but NGK wires are often blue :p
Old 11-10-2013, 12:47 PM
AudioFunk's Avatar
Where can I buy some NGK wires? and a cap
Old 11-10-2013, 08:21 PM
motoxxxman's Avatar
almost any parts store in the country
Old 11-11-2013, 09:35 AM
Sparksman's Avatar
True that! Ive actually asked if i could order some black ones at my local parts store and they told me they dont carry NGK black cables.... Not sure if the guy was just too lazy of a ***** to actually look it up for me. I ended up just getting blue ones, although would have preferred black for that oem look. Maybe later down the road il try to track down a set.
Old 11-13-2013, 03:59 PM
acedude180's Avatar
Never seen an NGK cap only NGK wires and plugs
Old 11-13-2013, 06:40 PM
jwarren1904's Avatar
iv got bosh wires with ngk plugs and i notice no difference. Its just a wire right?
Old 11-14-2013, 05:15 AM
acedude180's Avatar
Bosch are for European cars. It will work but NGKs r best for Japanese cars as they are manufactured in japan as well
Old 11-15-2013, 04:29 PM
motoxxxman's Avatar
bosch wires arc very easily, and the terminals almost always tear right off when you remove them. they're garbage imo. nothing with ever beat ngk wires (well MSD I think is comparable in certain circumstances)
95gsr916
04-02-2012 09:50 PM
Inextricabledrvr
06-22-2009 09:35 AM
accord94
04-17-2003 06:49 AM
b16ahybrid
02-18-2003 02:19 PM
SilverIntegra
04-02-2002 08:32 AM
Quick Reply: spark plug wires
