Balance shaft Removal??????s
Old 04-17-2007, 08:26 PM
LukieLuc's Avatar
Default Balance shaft Removal??????s
Is removing the belt around the balance shafts equivalent to removing the balance shafts, and plugging in oil holes in the baffle? If not whats the difference in performance, between stock and removing the belt around the balance shafts and removing them completely?
Old 04-17-2007, 08:40 PM
LukieLuc's Avatar
Default Re: Balance shaft Removal??????s (LukieLuc)
bump for ? above
Old 04-17-2007, 08:44 PM
nonvteclude's Avatar
its the same thing just witout removing the weight
moderator emeritus
98vtec's Avatar
removing the shafts completely drops more weight and raises oil pressure.
its cheap too so why not.
Old 04-17-2007, 08:52 PM
bluedlude's Avatar
Default Re: Balance shaft Removal??????s (98vtec)
cheap when your motor is out
LukieLuc's Avatar
i dont feel like removing the motor to do it, what are the benefits of the increase in oil pressure????
Old 04-17-2007, 08:53 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">i dont feel like removing the motor to do it, what are the benefits of the increase in oil pressure????</TD></TR></TABLE>
More leaks
Old 04-17-2007, 08:54 PM
LukieLuc's Avatar
Default Re: Balance shaft Removal??????s (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
More leaks </TD></TR></TABLE>
More leaks??? im sorry im pretty new in this, what do you mean?
Old 04-17-2007, 08:58 PM
kulrevon's Avatar
Removing the belt. You will basically gain hp because you have lightened up the reciprocating parts.
Removing the balance shafts removes weight. I think It possibly might increase oil pressure when you put in the plugs. and removing all of the balancer shaft stuff can allow you to move the pulley inward and can free up much needed space for things on the h2b swaps and the h22 in crxs and civics.
1.So by disconnecting the belt you gain the hp by loosing the spinning parts.
2. You can remove the the balancers to remove weight. or to gain some space.
Old 04-17-2007, 09:01 PM
LukieLuc's Avatar
Default Re: Balance shaft Removal??????s (kulrevon)
okay gotcha, One more ?, how much do the balance shafts weigh i heard like 30 pounds? is this true, is it worth it to pull the motor out to remove them? or do you sugest since i am a noob, i just pull the belt out?
Old 04-17-2007, 09:05 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">okay gotcha, One more ?, how much do the balance shafts weigh i heard like 30 pounds? is this true, is it worth it to pull the motor out to remove them? or do you sugest since i am a noob, i just pull the belt out?</TD></TR></TABLE>
No, about 8 lbs. I would not pull the motor to remove them, just cut the belt.
Old 04-17-2007, 09:08 PM
DfwBB6's Avatar
i wouldnt do it any other way motor has to come out if u see the process involved u will see why
Old 04-17-2007, 09:58 PM
Unidentified's Avatar
Default Re: Balance shaft Removal??????s (DfwBB6)
I hava a kaizen speed balance shaft removal kit up for sale if anyone is interested.
https://honda-tech.com/zero...age=4
Old 04-18-2007, 07:09 AM
LukieLuc's Avatar
Default Re: Balance shaft Removal??????s (Unidentified)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unidentified &raquo;</TD></TR><TR><TD CLASS="quote">I hava a kaizen speed balance shaft removal kit up for sale if anyone is interested.
https://honda-tech.com/zero...age=4</TD></TR></TABLE>
you might have a buyer i will pm you a price
fastdohc
10-04-2012 06:42 AM
BADxKARMAx
04-11-2012 04:11 PM
Tjabo
04-23-2010 01:16 PM
crix868
01-09-2006 09:47 PM
Ahknodd
05-29-2003 02:16 PM
Quick Reply: Balance shaft Removal??????s
