auto tensioner failer
Old 08-17-2015, 04:42 AM
stan xx's Avatar
Default auto tensioner failer
1998 Honda Prelude auto tensioner fail and the car died. I replaced the auto tensioner , water pump, timing belt and balancer belt and pulleys. Now it will not even turn over. I bump the starter solenoid and no spark to the plugs. Do you think the CKP/TDC sensors are bad. any help would be thankful. stan
Old 08-17-2015, 05:26 AM
moderator emeritus
98vtec's Avatar
Default Re: auto tensioner failer
This requires diagnostic and appropriate diagnostic tools. We can't tell you what's wrong over the Internet by only saying it doesn't have spark. There are many reasons it won't have spark but being you just did a bunch of work, you probably need to double check your work and make sure everything is plugged in and times correctly. Or you can listen to the next person that posts a random answer and go spend money and hope for the best.
are you sure valves were not damaged when the tensioner failed? Did it turn over initially after replacing the tensioner? Do you have the proper means to do diagnostics? Check engine lights? Have you checked for stored codes? Did you set timing correctly? Firing order?
There is a lot of essential information that is missing.
Old 08-17-2015, 07:28 AM
Apex1972's Avatar
probably bent the valves. pretty common if your tensioner fails.
Old 08-17-2015, 10:46 AM
holmesnmanny's Avatar
compression test to check the health of the motor
Old 08-18-2015, 08:42 AM
No tears. Only dreams, now.
VashTheStampede's Avatar
My tensioner failed last week, and it had no issues driving or running, save for the horrendous fluttering noise coming from inside the timing cover. What you're describing sounds a hell of a lot worse than a timing tensioner issue. You will likely need to get the car professionally diagnosed, as you could have snapped a belt, damaged the head, etc.
yourboyluigi09
06-05-2011 10:29 PM
3s_rolla
03-07-2011 01:05 PM
Matgallis
03-29-2009 01:48 PM
H22A4Vtec
05-30-2007 11:25 AM
david90
08-30-2003 07:32 PM
Quick Reply: auto tensioner failer
