Alignment on a lowered car
Old 09-14-2003, 11:18 PM
crj_lll's Avatar
Default Alignment on a lowered car
How does everyone with an Eibach Pro Kit get their car alignment done?
Old 09-15-2003, 07:48 AM
New User
aklucsarits's Avatar
Default Re: Alignment on a lowered car (crj_lll)
I don't have the specific springs you have, but my car is lowered. And I've never had any problems getting it aligned anywhere around here. I usually go to NTB because they have a 5000mi/60mo warranty on alignments, so I can usually get it aligned at least twice for the price of one.
Note that there is no camber or caster adjustment on the Prelude, so they only thing that they can correct is the toe settings.
Andrew
Old 09-15-2003, 09:28 AM
New User
laughinxxx's Avatar
Default Re: Alignment on a lowered car (aklucsarits)
I'm dropped 2.25 inches on H&R race springs and I was still within spec(barely). The only reason that I went in to get an alignment was because I knocked the toe out taking a corner too hard and hitting a reflector dome.
Old 09-15-2003, 09:56 AM
TraKtioN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aklucsarits &raquo;</TD></TR><TR><TD CLASS="quote">I don't have the specific springs you have, but my car is lowered. And I've never had any problems getting it aligned anywhere around here. I usually go to NTB because they have a 5000mi/60mo warranty on alignments, so I can usually get it aligned at least twice for the price of one.
Andrew</TD></TR></TABLE>
According to helms, everything is adjustable including caster by using shims. With a lowered car though you can only correct so much camber unless you get a camber kit.
Old 09-15-2003, 11:21 AM
HyperFlow's Avatar
when you drop a car the toe comes inside. Just go to any local shop that has the machine for alignments.
Just for example. i would do 5000kms to a set of tires. now i'll do 20-30
Old 09-15-2003, 03:33 PM
fIame0ut's Avatar
Default Re: Alignment on a lowered car (HyperFlow)
actually lowering changes camber..
looking at a tire front the front or back of a car and camber would look like / / or \ \
looking at a tire from above or below and toe would look like this / / or \ \
also, ive found that most alignment places dont like to do lowered cars, or charge more for it. ive had two places now that couldnt get my car up on the ramp..
Old 09-15-2003, 03:44 PM
TraKtioN's Avatar
Default Re: Alignment on a lowered car (fIame0ut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fIame0ut &raquo;</TD></TR><TR><TD CLASS="quote">actually lowering changes camber..
also, ive found that most alignment places dont like to do lowered cars, or charge more for it. ive had two places now that couldnt get my car up on the ramp.. </TD></TR></TABLE>
lowering changes, camber, toe and caster. All 3.
Old 09-15-2003, 06:45 PM
HyperFlow's Avatar
Default Re: Alignment on a lowered car (TraKtioN)
yes but you cant change the camber without a camber kit on a honda. Plus it will rub. Just adj the toe and you will get so much more life out of your tires. I ride my car slammed so it made a huge diffrence for me
Old 09-15-2003, 07:47 PM
MugenPoweredLude's Avatar
yea you cant adjust camber without a camber kit
its recommended to set the toe to 0 in the front
Old 09-15-2003, 09:29 PM
fIame0ut's Avatar
Default Re: (MugenPoweredLude)
i fail to see how lowering our cars with the double wishbone suspension changes toe and caster.
Old 09-16-2003, 06:44 AM
jc836's Avatar
Default Re: (fIame0ut)
Since you fail to see the issue-please read the articles on both the Ingalls and SPC websites on the subject. Also note that any time you disassemble a suspension there is a strong chance that you will change the settings. Minute changes in either toe-in or Caster cannot be seen but have a real impact on handling for some cars.
This is not a flame-I do think reading will help you better understand how the relationship of the position of parts affects a car.
Old 09-16-2003, 11:37 AM
JDM GIRL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aklucsarits &raquo;</TD></TR><TR><TD CLASS="quote">Note that there is no camber or caster adjustment on the Prelude, so they only thing that they can correct is the toe settings.</TD></TR></TABLE>
To go along with that, here is what alignment did for me...not too much obviously.
Old 09-16-2003, 12:10 PM
Greyout's Avatar
Default Re: Alignment on a lowered car (JDM GIRL)
looks like you're missing a washer on the front right tie rod...
also, If I remember correctly my toe went out, not in, when my car got dropped.
Old 09-16-2003, 07:58 PM
machinehead's Avatar
how much is an allignment and how much is a camber kit?
Old 09-17-2003, 04:21 AM
JDM GIRL's Avatar
Default Re: (machinehead)
It cost me like $30 at Honda for an alignment, but I'm sure if you look around you could probably find it for cheaper. If you are looking into camber kits, check into Ingalls. Here is a site that shows the prices of these camber kits. Check it out: http://www.lightningmotorsports.com/ingalls.htm. How much is your car dropped?
Old 09-17-2003, 09:31 PM
crj_lll's Avatar
Default Re: (JDM GIRL)
#1, thanks everyone for all the responses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM GIRL &raquo;</TD></TR><TR><TD CLASS="quote">It cost me like $30 at Honda for an alignment, but I'm sure if you look around you could probably find it for cheaper. If you are looking into camber kits, check into Ingalls. Here is a site that shows the prices of these camber kits. Check it out: http://www.lightningmotorsports.com/ingalls.htm. How much is your car dropped?</TD></TR></TABLE>
#2, Where the hell do you live? LOL I want to move where ever you are that a 4 wheel alignment cost only $30. Here in Philly, from the Honda dealer, it runs me $69.99 plus additional because it is lowered. LOL
#3, I am putting on a full Inglas camber kit. Should be able to fix everythiing and hopefully get all measurments to dead zero.
Again, thanks to all
Old 09-18-2003, 05:14 AM
JDM GIRL's Avatar
Default Re: (crj_lll)
Oops, I totally forgot that was the price with an employee discount. My bad.
FlewByU352
Suspension & Brakes
12
11-27-2009 06:20 AM
SpeedMachine
Suspension & Brakes
11-07-2005 09:38 AM
Wazup
07-13-2005 07:04 PM
spooniq
Honda S2000
09-07-2004 01:04 PM
otb2000itr
Honda S2000
21
09-05-2004 08:41 AM
Quick Reply: Alignment on a lowered car
