99 prelude smoking- A LOT of oil going in from pcv valve.
Old 06-04-2015, 09:43 PM
99bb6-vtec's Avatar
Default 99 prelude smoking- A LOT of oil going in from pcv valve.
I have a 99 prelude base, to cut to the point my pcv valve is spitting an excessive amount of oil into my intake which makes my car smoke and smell like it's burning oil... is there a dramatic difference between the oem pcv's flow rate and the auto stores pcv's flow rate that would help me solve my issue???
Old 06-05-2015, 07:10 AM
Moderator
snobordboy's Avatar
Default Re: 99 prelude smoking- A LOT of oil going in from pcv valve.
If you are getting that much oil through the pcv, you probably have excessive blowby, and are burning oil from the rings as well. I would do a compression test and leakdown test, but it is probably time for a rebuild.
Old 06-05-2015, 07:43 AM
99bb6-vtec's Avatar
Yea I was afraid of that answer, but I I have heard that before so it's most likely my problem, but also let me add it doesnt constantly smoke, it only smokes at times like when i down shift into 4th and third... i got a cheapy oil catch can but it wasnt baffled so i helped for a little bit then the oil started to go through the line again.... but when theres no oil in the intake or pcv lines it doesnt smoke or smell like burning oil....thanks man
prionailurus
13
02-19-2008 07:36 PM
tzych
05-15-2007 07:16 PM
Jeff
04-18-2005 06:23 AM
MathewAshley
09-29-2004 01:07 PM
Accel Junky
04-28-2003 02:18 PM
Quick Reply: 99 prelude smoking- A LOT of oil going in from pcv valve.
