99 lude swap
Re: 99 lude swap
Give it time, this isn't Facebook where people will spam answers off the top of their heads.
What did you do about the oil pump, what distributor are you using, what injectors are you using, what ecu are you using, are there any connectors that are not plugged in?
Re: 99 lude swap
jdm oil pump and dizzy usdm intake and injectors, tried both ecu's everything is plugged in
Re: 99 lude swap
It should fire with the Crank Position sensor in the distributor.
Your going to need to break out the Multimeter and see what's up.
I could be something simple like a bad ignitor or coil. Is it internal coil or external? JDM should be internal. I assume you removed the external and used the correct CAP and wires.
