98 Prelude - no vtec, redline 6500rpm - Page 2 - Honda-Tech
Old 02-28-2017, 08:35 PM   #26
Default Re: 98 Prelude - no vtec, redline 6500rpm
it didnt work with oem oil pressure switch either?
did you adjust the valves? was there everything "ok" inside the head?
are you 200% sure that you have H22A ecus since H23A1-3 have that 6500rpm rev limit and no vtec...
TimiK is offline   Reply With Quote
Old 03-01-2017, 01:47 AM   #27
hondamyheart's Avatar
I did adjusted the valves.Yeah the vtec wasnt working thats why i installed the AEM sensor and gauge to view the oil pressure. It is reading 30 to 35psi idle and it will increase through RPM range to max 75psi. Ecus p13 and p28 chipped with h22 basemap.
hondamyheart is offline   Reply With Quote
Old 03-01-2017, 02:22 AM   #28
how about your temp sensors (theres 3 of them) do they work properly?
did you replace all of them or just one? have you used oem sensors?
Old 03-01-2017, 09:40 PM   #29
I replaced the ect sensor under the distributor and the sensor next to it the sending sensor. Where is the third one?
Old 03-02-2017, 01:01 AM   #30
Old 03-02-2017, 01:06 AM   #31
Thanks a lot buddy. I will replace it this weekend and will give an update.
Old 03-02-2017, 03:25 AM   #32
but if I remember correctly that has more things to do with fans....
next step could be then to see if valvetrain works perfectly - rockers move how they should etc (unless you checkd that when you adjusted valves)
vtec not working....another one rhdej2 Honda Civic / Del Sol (1992 - 2000) 12 03-04-2010 06:47 AM
My JDM h22a Contender_h22a Honda Prelude 28 10-28-2009 08:35 AM
VTEC Problem!?! accordingtoh22 Honda Prelude 3 05-21-2007 07:55 PM
h22a problems IOSUA Honda Prelude 11 11-22-2005 05:16 AM
ECU Code? td04civic Hybrid / Engine Swaps 3 10-02-2002 08:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
