98 h22a4 oil light flashes
Re: 98 h22a4 oil light flashes
Sounds like you need to test it with an actual gauge. You may have a bad oil pump, or bearings that are loose to the point that oil pressure is not building well.
Be very careful if you start hearing noise from the bottom end, a spun bearing or worse may soon follow.
garthjenkins
08-06-2011 01:35 PM
1999blownlsturbo
12-15-2006 10:32 PM
