94 H22 totaled
94 H22 totaled
i wrecked my 94 lude a few years ago it ran great until I experimented with sleeping and driving. After 2 years of sitting after the wreck what all will need to be checked before test starting it to sell it? Oil is full. Radiator shattered both airbags blown (immobilizer maybe?) flipped multiple times and stalled on its roof. What would this swap donor car be worth 144,244 miles clutch timing belt water pump and all front seals rear seal and oil pan gaskets replaced about 14,000 before the wreck. Always serviced at 2,750 miles since 60,000 miles all records available.
Re: 94 H22 totaled
Sitting for a few years after flipping? I would drain the fuel and replace with a bit of new fuel, and make sure the lines are clean. There is a safety switch that should kill the car when it flips, so that should be checked.
If you just want to turn it over, it "can" run without coolant, but not for long. I would say first off pull the plugs, and put the trans in neutral, and try to spin the engine by hand. If it turns ok, then maybe put the plugs back in and try to fire it up.
redzcstandardhatch
11-20-2006 07:01 AM
