5th gen Fog lights
5th gen Fog lights
I got genuine JDM Honda Clear fog lights, the fog light switch with cruise, moonroof, etc
and the harness that goes to the back of that and down to the cabin fuse box and theres a ground and couple other things hanging off it. Is this all I need? Like when I pull off the Fog light "dummy covers" under the turn signals will there be a harness to connect them?
Re: 5th gen Fog lights
Ok from what I have gathered I dont have the exterior wiring harness hoo ha for me. and the fog light switch I have has all my other switches just fog is where my pocket was and is no more Does this mean I can just use the switch when ever I want with or without key in the ON position or option b with daylights on? this Is only what I have gathered reading through to different DIY's and they are exactly the same.
Is it that hard to just make your own Ext harness? I'm guessing the orange wire just goes to both positives, and I ground out both negatives? Would that work.
Thnx! I did it today got my Fogs In! IDK if I can post pics or not but all grab a couple tomorrow and try. Finished just before sun down with a friend and flashlight. hardest part was finding that orange wire inside cabin. Does anyone know what the other to connectors taped up are? that are down there not connected to anything. One was a three wire connector and the other was a to wire with connector taped to wire harness with blue tape.
Making the ext. harness was easy enough. 18-16G wire and some connectors. and 7ft of wire loom. still need to find a better place to tuck it or zip tie it. I didnt think it would be a good idea to zip tie to the power steering cooler.
ITLNstallion818
08-14-2007 09:20 AM
GSR_96814
09-21-2006 01:42 AM
