4th gen cables into a 5th gen (one way to get a 4bidden SS for 5th gens)
Old 12-21-2006, 06:59 PM
moderator emeritus
98vtec's Avatar
Default 4th gen cables into a 5th gen (one way to get a 4bidden SS for 5th gens)
So as many of you know, my shift cables snapped and i went through alot of grief with UPS losing my package containing the 5th gen cables that precisionh23a had sent me. Good thing he insured the package!
He overnighted me a set of 4th gen cables and a 4th gen base plate. Once i got the package today, i was a little worried about getting the plate mounted securely because it was just so much longer than the 5th gen plate and only the two back holes lined up. At the top of the plate it lined up with two unthreaded holes, my option there was to drill through the holes and through the underside of the chassis allowing me to use long bolts and two nuts to secure the top of the plate down.
I was at sears trying to pick out the right drill but after thinking about it, there was just no room to get a drill where i needed it to be. Called up anthony to see if he could give me some pointers. Told me to get some sheetmetal screws and use them to connect the base plate to the thin piece of sheetmetal on top of the chassis. So i got a drill, bit set and a 3/8" bit.
I DID NOT end up using the sheetmetal screws. In the picture below, it shows how i bolted the top part of the mount down. That is the factory bolt from the 5th gen shifter.
as you can see there is a good difference in design and size. Not to mention that the 4th gen shifter is SO much beefier than the 5th gen shifter.
theres really no reason to explain the next section because a picture is worth a 1000 words.
In the last picture you can see that i have to use my dremel and cutting wheel to pull a tab of the plate out so the bolt would seat correctly. No biggie.
so all you need is a drill, 3/8ths metal bit, dremel with cutting tool, 10mm/12mm socket, cotter pins, and pliers and you'll be good to go.
going to be ordering the 4bidden shifter once i sell my LEAN short shifter.
Any questions just let me know, its pretty damn straight forward tho.
Modified by B.Rabbit at 6:19 PM 1/8/2007
98vtec is offline
Old 12-21-2006, 07:03 PM
SOHC-VTEC-BB2's Avatar
Default Re: 4th gen cables into a 5th gen (B.Rabbit)
Very nice! Excellent idea. Turned a rather negative situation into a positive outcome.
Good Work!
SOHC-VTEC-BB2 is offline
Old 12-21-2006, 07:13 PM
moderator emeritus
98vtec's Avatar
Default Re: 4th gen cables into a 5th gen (LudeFanatic)
i must thank anthony (precisionh23a) once again for being the great guy he is and hooking my up with the 4th gen assembly with advice on how to get them in and not completely throwing me to the wolves.
really appreciate that man
I can honestly say that you 4th gen guys are lucky. My shifts have never felt this solid before and this is with the stock shifter. It's a much mor solid design IMO.
98vtec is offline
Old 12-21-2006, 07:18 PM
prelude1897's Avatar
looks sweet...So how much better is the 4Bidden shifter than the Lean shifter?
prelude1897 is offline
Old 12-21-2006, 07:20 PM
moderator emeritus
98vtec's Avatar
Default Re: 4th gen cables into a 5th gen (prelude1897)
i couldnt tell you. I dont have it.
98vtec is offline
Old 12-21-2006, 07:35 PM
VTecLude1994's Avatar
You'll love a Forbidden SS. Honestly one of the best purchases for my car. It just feels so nice and I'm on the top notch (shortest throw).
VTecLude1994 is offline
Old 12-21-2006, 07:40 PM
Default Re: 4th gen cables into a 5th gen (VTecLude1994)
Yea, the Forbidden SS was also one of the best investments I made as well.
I run top notch and it feels smooth and precise. Only complaint is the rubbing issue. I keep trimming and it still catches occasionally. (that issue may be even worse with the 5th gen console design)
Old 12-21-2006, 07:41 PM
moderator emeritus
98vtec's Avatar
i dont use my center console.
98vtec is offline
Old 12-21-2006, 08:40 PM
hamadiscool's Avatar
This gives me hope. There is a guy I know selling shifter and cables from a 4th gen for $50. I am gonna do a manual swap soon in a 5th gen and I am guessing that I can use those parts, is that a good price and do you recommend me doing this for daily driving?
hamadiscool is offline
Old 12-21-2006, 09:20 PM
Hawkze_2.3's Avatar
Good stuff
Wait until you get a 4bidden SS ...
Hawkze_2.3 is offline
Old 12-21-2006, 09:30 PM
raylude's Avatar
Location: united states of mexico and yes ladies i am, available
nice
do you mind if i ask if the cables showed any symptoms before they broke? my shifter is feeling weird i can put it in any of the top gears and it has like an inch or 2 of play if you keep pushing it forward and makes me miss gears sometimes
raylude is offline
Old 12-21-2006, 09:35 PM
RTFM
v4lu3s's Avatar
i hadnt seen anyone else put the 4th gen shifter and cabels in, i did it with my wifes 99 lude a few years back cause i stretched her cables out shifting hard and could only find 4th gen repalcement parts.
v4lu3s is offline
Old 12-21-2006, 10:18 PM
moderator emeritus
98vtec's Avatar
Default Re: 4th gen cables into a 5th gen (raylude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude &raquo;</TD></TR><TR><TD CLASS="quote">nice
do you mind if i ask if the cables showed any symptoms before they broke? my shifter is feeling weird i can put it in any of the top gears and it has like an inch or 2 of play if you keep pushing it forward and makes me miss gears sometimes </TD></TR></TABLE>
well, my cables had had their battles in the past and with 140k on them, prolly wasnt a smart idea to mess with full throtle shifting with that kinda mileage. And also, upon first inspecting everything, i notice that my shifter base was a little loose. I have polyurathane bushings and i guess with all vibrations the bolts back out over time.
I've had this shifter and bushings for like 3 years and had never thought to check them out every once in a while to see if they needed to be retightened.
it broke at the point where the cable is mounted to the shifter base which i think means that everything pretty much went wrong
98vtec is offline
Old 12-22-2006, 08:03 PM
PrecisionH23a's Avatar
Hey Blake, I'm glad everything worked out for you. Sorry again about the UPS mix-up... but it looks like things turned out better by going with the 4th gen cables
The 4th gen shifter plate owns the 5th gen plastic pos.
PrecisionH23a is offline
Old 12-22-2006, 08:48 PM
Mykizism's Avatar
Default Re: 4th gen cables into a 5th gen (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">
The 4th gen shifter plate owns the 5th gen plastic pos.</TD></TR></TABLE>
but, still chrome pro owns hondata s300
Mykizism is offline
Old 12-22-2006, 09:22 PM
moderator emeritus
98vtec's Avatar
Default Re: 4th gen cables into a 5th gen (Mykizism)
youd shut ur mouth if you knew it was good for yuh buddy
Crome &gt; Chrome
98vtec is offline
Old 12-22-2006, 09:40 PM
street_accord94's Avatar
nice job blake. wait till you get the 4bidden in...i love mine
street_accord94 is offline
Old 12-22-2006, 10:13 PM
saikou's Avatar
Default Re: 4th gen cables into a 5th gen (street_accord94)
Nice pants...
Must be a real nice shifter if it is amongst one of the best investments people have done to their 4th gens. Can't wait till I get mine.
saikou is offline
Old 12-22-2006, 10:15 PM
moderator emeritus
98vtec's Avatar
Default Re: 4th gen cables into a 5th gen (saikou)
Seminoles FTMFW
98vtec is offline
Old 01-12-2007, 02:18 PM
raylude's Avatar
i just picked up a shifter and cables from the junk yard for $50
but where can i find those red bushings?
raylude is offline
Old 01-15-2007, 10:47 PM
moderator emeritus
98vtec's Avatar
hell yea man. Your really gonna like how solid it feels
my bushings are just polyurethane that Lean gave me when i bought his shifter way back when. I'm sure you can use the stock 4th gen bushings without any problem. When you drill the new hole, you can prolly go to lowes and make your own bushing.
btw, i just bought a 4bidden shifter tonight
98vtec is offline
Old 01-16-2007, 07:52 AM
GtechPro's Avatar
You're gonna love it! I have mine on shortest and it still feels rock solid.
One more thing I wanted to share...
There have been a few guys, including myself, who broke the plastic piece that goes over that ball. Mine just snapped in half as I was trying to get it off the OEM shifter, and I was very gentle too. It's a nasty piece to take off.
In case you break it, don't panic
You can still use it. Just put the two pieces together over the ball and put it back in place as you're installing the 4bidden shifter. They really have nowhere to go. I measured the two pieces and the ball, then measured the opening they go into, and concluded that everything should still work as normal even though the piece is broken in half. And sure enough, a few months later it's still in place and performing just fine.
GtechPro is offline
Old 01-16-2007, 08:47 AM
budget's Avatar
i have a 4th gen shifter and cables if anyone wants to get it
budget is offline
Old 01-16-2007, 09:20 AM
97Preludeguy's Avatar
Default Re: 4th gen cables into a 5th gen (budget)
The Forbidden is awesome. I run mine on the top notch and its nice and short without being notchy. I didn't install poly bushings with mine though, I just bought washers and stacked them up
97Preludeguy is offline
Old 01-25-2007, 12:39 PM
thelonerangers's Avatar
Default Re: 4th gen cables into a 5th gen (97Preludeguy)
im interested in the 4th gen parts if u still got em. do i need to change the cables also if im swapping those into a 5th gen or i can use the exsisting cables?
thelonerangers is offline
Quick Reply: 4th gen cables into a 5th gen (one way to get a 4bidden SS for 5th gens)
