2000 prelude - abs light - 6 long 1 fast. - Honda-Tech
Old 08-16-2009, 08:36 AM   #1
jay24k's Avatar
Default 2000 prelude - abs light - 6 long 1 fast.
I jumped my ABS light sensor and I'm getting what I think is 6 -1. I'm assuming you just count the times the light appears. The last flash is very quick and the rest are longer. Does anyone know if that is ignition voltage or right wheel sensor? I've seen two different code lists.
Thank you.
jay24k is offline   Reply With Quote
Old 08-16-2009, 08:46 AM   #2
ArmaanOG's Avatar
Default Re: 2000 prelude - abs light - 6 long 1 fast.
abs computer prob took a crapper.. get a new 1
ArmaanOG is offline   Reply With Quote
Old 08-16-2009, 09:11 AM   #3
jay24k's Avatar
Is there anyway to verify that? The reason I ask is when I tested my 12V constant wire in the past and the car cranked it would drop to around 7V during the process. I'll do some more testing but wasn't sure if maybe it did have to do with the voltage issues or not.
Old 08-16-2009, 09:22 AM   #4
vinuneuro's Avatar
61 is an ignition voltage code. The troubleshooting procedure is to basically check the charging system. Do you have the service manual?
vinuneuro is offline   Reply With Quote
Old 08-16-2009, 09:24 AM   #5
jay24k's Avatar
Just downloaded it. I guess I was reading the engine light blink because that was on too. I assumed that would flash the error for the ABS with the jumper. I Cleared that by pulling the fuse and the ABS light never blinks giving me any codes at all. It just stays on. Service manual has a process for checking why it doesnt turn off so I'll go through that unless anyone has better advice.
Old 08-16-2009, 10:45 AM   #6
jay24k's Avatar
Did all the troubleshooting and noticed the light turned off when I reseated the instrument panel cable. Go figure. Should of checked that first since it was the simplest.
Thanks for the suggestions guys.
Integra abs WSS m90polk1 Want to Buy 0 02-14-2017 06:26 AM
ABS light... Need help resetting it... Incognito Acura Integra Type-R 14 05-12-2016 05:44 AM
ABS LIGHT, JdmLub Honda Civic / Del Sol (1992 - 2000) 0 09-08-2005 07:53 PM
ABS Light, no code... LudeinMD Honda Prelude 8 02-10-2005 09:52 AM
Abs Speed Sensor... Abs light is on... rusureboutdat Acura Integra 6 09-02-2004 06:28 AM
Tags
00, 1992, 2000, 2000prelude, 2001, 61, 95, abs, blink, code, codes, honda, light, prelude, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
