2000 coolant leak
Old 01-17-2010, 11:27 PM
stakskits's Avatar
Default 2000 coolant leak
i recently posted asking for help on a coolant leak. i cant seem to figure out the problem. what could cause a coolant leak near the firewall and spark plug wire distributor?
Old 01-18-2010, 04:29 AM
Hawkze_2.3's Avatar
Default Re: 2000 coolant leak
A bad gasket or a cracked part. Pics would really be helpful here............
Old 01-18-2010, 12:44 PM
stakskits's Avatar
here are some pics, might be hard to tell where its coming from, i cant even really tell
Old 01-18-2010, 05:59 PM
Hawkze_2.3's Avatar
Well, you're pointing at the thermostat housing, so it could be that gasket or one of the hoses going to it. If it were me, I would pull that housing and check it out (drain coolant a bit, remove intake, remove rad hose, unbolt housing and remove, etc...).
Old 01-19-2010, 01:11 AM
I want to be in your sig's Avatar
I have had a coolant leak in that general area before. It's one of the black rubber hoses right under the distributor.
beamer
04-20-2018 09:41 AM
grndslm
09-04-2013 10:05 PM
Jettplane
09-09-2012 08:37 AM
nukem384
06-13-2009 06:18 AM
stdefhatch
07-15-2007 07:27 AM
Quick Reply: 2000 coolant leak
