1998 Prelude
1998 Prelude
I have an automatic 1998 prelude. It looks like it was in a flood, everything has been replaced, fuel pump, plugs, wires, distrubuter, all fuses, exedra. Motor is in good condition. Last things is no spark, has voltage but just not giving spark, fuel pump primes. ECU and controller have not been replaced. So I'm thinking ECU . Question is if I buy a used one do I need to have a chip put to keep from buying a key and controler or what are my options. I'v read several several threads and can't find a solid answer. Any help is very appreciated.
Re: 1998 Prelude
I'v already done that, I'm just trying to find my options of what has to be replaced with the ECU. It rained last night and the car apparently also has the notorious Lude passenger leak. And the previous owner had the dash taken out at some point in time and did not put the drain tube back in the correct place. There are literally water marks on the control unit.
Re: 1998 Prelude
A 1998 will have the immobilizer, so if you buy another ecu, you need the keys and locks/ ignition switch to match it, or will have to get things re-programmed.
Re: 1998 Prelude
Thats what I thought, I know you can also buy a dummy chip and then bypass the keys & locks/ ignition switch. But I not sure on the exact name. Do you know if I need the exact same year ecu?
Re: 1998 Prelude
Or the option to do the obd1 converstion which will by pass most of the security , you do have to do a little your self I belive and possible dummy chip. I just cant find solid answers anywhere.
Re: 1998 Prelude
Never heard of the dummy chip thing.
If you buy an obII to obdI adapter and run an pbdI ecu yes, but I don't know if you can find one that will control the SS trans in the 5th gen.
