1992 Prelude Transmission Help
I'm new to all this and need help. I just bought my 17 year old a 1992 Honda Prelude SI, H23A1. It has a header, loud muffler and a cold air intake. Having fantasies of the Fast and Furious, he blew a gear through the side of the transmission about 20 minutes after he I gave it to him (3rd car he's totaled and or broken in some fashion or another in 18 months). The marking on the transmission he blew was M2S4. I have found two Honda transmissions at the local Pick-N-Pull marked H2U5 and P2A4, both out of Accords. Are these considered "F" series transmissions? Will they bolt up to my 1992 Prelude H23A1? Thanks!
Re: 1992 Prelude Transmission Help
Yeah, he wont be accelerating fast any where with those, maybe it'll teach him a lesson. If you wanted to though you shouldn't have much trouble finding another M2S4, most people discard them for a closer geared transmission.
go to http://www.hondaautomotiveparts.com and you can rebuild the transmission you already have.
if they're out of the accord....you may have to drill and tap the a tranny mount hole or 2. I blew my heavily abusd 240k mile m2s4 trans, replaced it with trans from a f23 accord. Bolts to the block just fine, reused the axles....but the accord trans mount has a slightly different bolt pattern. I had to drill the f23 trans and tap the holes. The hole locations are there, but unthreaded....or save urself the headache and get the mount found it also
