1992 honda prelude 2.3 si oxygen sensor wiring diagram - Honda-Tech
Old 10-12-2006, 05:06 AM   #1
92preludesi2.3's Avatar
Default 1992 honda prelude 2.3 si oxygen sensor wiring diagram
I just got this denso aftermarket o2 sensor and there is no harness on it, so i have to take the old harness and put it on the new sensor. Do you have a pic or can you tell me what the wires are on the original o2 sensor, ground, heater wire ect...
If not can you tell me how i can find out.
92preludesi2.3 is offline   Reply With Quote
Old 10-12-2006, 07:19 AM   #2
Finest's Avatar
Default Re: 1992 honda prelude 2.3 si oxygen sensor wiring diagram (92preludesi2.3)
I don't have my O2 sensor in front of me, so this is going off the Helms manual:
Using this diagram, you're looking at the O2's connector:
The Helms lists the connector from the wiring harness side, so the coordinating wires on the O2 connector are:
Top right: (heater +)
Top left: (heater - )
Bottom right: (sensor + )
Bottom left: (sensor - )
Hope that helps.
Finest is offline   Reply With Quote
4-Wire oxygen sensor DRatedA.W.D. Honda CRX / EF Civic (1988 - 1991) 8 09-02-2015 09:25 PM
Wire Color?? BIG T Tech / Misc 3 05-08-2008 08:09 AM
5 wire O2 sensor to 4 wire O2 sensor harness...help lv6l Honda Civic / Del Sol (1992 - 2000) 11 04-08-2008 02:10 PM
o2 sensor problem superturboprelude Honda Prelude 7 10-21-2003 02:48 PM
wiring my o2 sensor directly to my ecu? bdicustoms Honda Civic / Del Sol (1992 - 2000) 2 05-27-2003 07:30 PM
Tags
02, 1992, 92, 99, civic, diagram, honda, location, o2, oxygen, prelude, removal, sensor, si, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
