01 Prelude H22A4 Timing Belt Noise - Honda-Tech
Old 02-24-2017, 09:32 AM   #1
Default 01 Prelude H22A4 Timing Belt Noise
I have a 2001 Prelude Base 5spd 115k. The previous owner supposedly did a timing belt/water pump.
I am noticing a ticking type noise from the auxiliary area of the engine when above 3,500rpm or so.
I have listened closely to the alternator and power steering pump, I don't think it is coming from there.
It sounds like its coming from under the timing cover. I know these motors use an automatic tensioner that tends to be a known problem.
Obviously the thing to do is remove the timing cover and check the tension and check for any signs of the belt hitting something and I do plan to do that.
Has anyone else had this problem? A loose belt or tensioner problem perhaps? Has anyone had their belt rub or hit on something under the timing cover?
I've parked the car for the winter and don't want to drive it for fear of the belt slipping or jumping timing.
Thanks,
-Ian
Accordian47 is offline   Reply With Quote
Old 02-25-2017, 03:03 AM   #2
Default Re: 01 Prelude H22A4 Timing Belt Noise
try to open it and look what is going on there?
and tighten everything while youre there..
do you know what parts previous owner new'd? just because you kinda need to new the "tensioner pulleys" there as well when youre doing the timing job
TimiK is offline   Reply With Quote
Old 02-25-2017, 09:54 PM   #3
Seafoam it and look for smoke billowing out of the exhaust manifold gasket area. When you got an exhaust leak it sounds like ticking.
holmesnmanny is online now   Reply With Quote
Timing belt walk (please help!!) CptHMCrunch Honda Prelude 6 02-12-2017 02:24 PM
Noise then smoke after second timing belt change - AC compressor issue? WaryDriver Honda Civic / Del Sol (1992 - 2000) 64 10-12-2015 07:34 AM
Timing belt change procedural questions not replacing tensioner WaryDriver Honda Civic / Del Sol (1992 - 2000) 7 08-11-2015 06:19 PM
Noise from timing belt area after warmed up & low idle...cause? Speedfiend97LX All Motor / Naturally Aspirated 14 12-29-2014 03:10 PM
Correct Method for Timing Belt Tension yosuthnmasa Honda Civic / Del Sol (1992 - 2000) 8 04-08-2008 07:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
