00 prelude transmission injury
Old 02-01-2014, 01:51 PM
gman4w's Avatar
Default 00 prelude transmission injury
hi guy i have a honda prelude base model 5 speed few day ago a try to go on reverse but when i try to shift on reverse it doesnt go in kind of block shift pushu really hard but not go in the other shift go in whitout problem. anyone have this problem, thanks for u help.
Old 02-02-2014, 07:31 AM
Canuckian
Lugzilla's Avatar
A lot of times the gears are just misaligned, try shifting into first or third before you shift into reverse. I do this habitually in my '01, its a pretty common thing on our cars.
Old 02-06-2014, 07:13 PM
1986Cbracing's Avatar
Default Re: 00 prelude transmission injury
On a lot of manuals in general. I have an old GMC Truck I have to do the same thing to and an old 89 Toyota that I have to shift into 1st or 3rd then go to reverse.
Old 02-06-2014, 09:19 PM
MOTORVATIONS's Avatar
I have repaired many H22 transmissions with this problem. Usually, the 5/R slider sleeve is damaged on the opposite side of the "lost" gear, burred badly enough that one cannot pull the sleeve thru the slider to engage the opposing gear. (Grind 5th: lose reverse. Grind reverse: lose 5th)
Parts and labor to repair this issue through a reputable shop could cost as much as a used transmission in today's market... but at least you would know what you have then. A used trans is always a crap-shoot.
Old 02-07-2014, 04:57 AM
Kool-Lude's Avatar
My trans. does the same thing. We should rebuild ours.. as Motorvations suggested, but if you open that thing up, might as well add a performance upgrade...LSD!!! Quaife or MFactory is what will be going in mine soon.
Old 02-07-2014, 11:40 PM
holmesnmanny's Avatar
a lot of times you gotta shift into first before you can go into reverse this is a common issue with any tranny imho
thirsk66
10-22-2013 11:15 AM
euroticcustoms
Transmission & Drivetrain
03-06-2013 05:52 PM
Skyblade
03-04-2008 02:17 AM
prelude2boost
12-23-2003 03:04 PM
Preludekid5
06-11-2002 01:46 PM
Quick Reply: 00 prelude transmission injury
