power commander 3 usb question
anybody here uses the PC3 USB? what mods do u guys have and how do you guys like the PC3 USB. is it worth getting eventhough i only have a slip on exhaust. thanks
Re: power commander 3 usb question (trbo823)
I'm pretty sure my bike only has the exhaust and K&N and I have the 3 so i think u should be all set.... but i have no idea if my bike has anymore those are the only ones i know of???
actually i was wondering the same thing. i was at my local mc shop and they had a special on the micron slip on and according to them, the PC3 is really useful when you get a full aftermarket exhaust (like headers and onwards). PC3 would probably help eke out a bit more with the slip on, but probably overkill. if u have more significan, future mods in mind, then it would definitely help.
I'm currently running the PC3 USB on my RR and have an Erion Slip-on. I must say that I've noticed a smoother acceleration and the flat spot at 10K RPM seems to be taken care of. The only complaint I had with the PC3 was that I bought one of the first batches, which had problems with stalling the bike. After sending it back to Dynojet haven't had a problem. Good Luck
Re: power commander 3 usb question (clockedout)
You could always tune your bike a little better even from stock. Its just do you have the extra money for the small gains of just a slip on? I would save my money. Still the best results will be from putting your bike on a dyno and tuning it instead of just using a set map.
Re: power commander 3 usb question (Etylorcen)
thanks for the replies. really helpfull. im probably gonna add more aftermarket stuff as i get more cash. i was just debating if i should get it now with the slip on or get it later on when ive added more aftermarket performance parts. thanks
If you get the pciii... take it to the dyno and have it tuned. My bike made a significant amount of horsepower over stock with only a slip on. I had a full system and it only made 0.8 more hp up top and lost about 1-2 mid range so I took it off.
Muffler Bearing
Honda Motorcycles
10-15-2005 02:29 PM
typeeg
Honda Motorcycles
12
09-27-2004 07:32 AM
