newbie w/ shadow 750 ACE starting problems - Honda-Tech
Old 06-11-2007, 12:34 PM   #1
shadownin's Avatar
Default newbie w/ shadow 750 ACE starting problems
First off, let me introduce myself. My name is Mike, I'm in the Air Force, live in Wyoming, and just recently got the 'go-ahead' from the 'boss' to get my first bike. So, last week, I picked up a beautiful 2003 Shadow ACE. Looks great, unfortunately, I'm having problems starting her.
I know this is a really dumb topic, but I've gone through the manual, this forum, and many other forums and for some reason can't find an answer.
When I try to start her, everything is on (fuel switch, engine shut-off switch, ignintion, and in neutral w/ the choke out and kickstand up & down) and is full of fuel, I push the start button, she turns... and turns... and turns. A friend came by, we checked the spark plugs, which were wet, so we cleaned them off, made sure there wasn't any fuel left, put the plugs back in, and tried again, with the choke out, with it all the way in, and a little in between. No luck. We then checked the battery, was pretty low, so charged it up, and tried again. Still no luck. At this point I'm pretty frustrated because this is my first bike and don't know what to do. SOMEBODY HELP!!!
shadownin is offline   Reply With Quote
Old 06-11-2007, 12:49 PM   #2
that one guy's Avatar
Default Re: newbie w/ shadow 750 ACE starting problems (shadownin)
check to see if ur gettin spark to the plugs, take plugs out and turn it over a few times cause you might have flooded it, check air filter and intake system so its getting air, check carbs arnt gunked up or if its fi make sure throttle boddies are functioning and injectors are injecting. basically think of the 4 steps the engine goes through and check everything that makes that step work until it runs.
that one guy is offline   Reply With Quote
Old 06-11-2007, 01:09 PM   #3
My Name is Nobody
MSchu's Avatar
Default Re: newbie w/ shadow 750 ACE starting problems (that one guy)
you flooded your bike... never continue to crank a bike if she wont fire up fairly quickly, this is a sure fire way to kill a stator. MAKE SURE your plugs are good, take one out and plug it into the plug wire and set the electrode on a steel surface on the bike... if you do not see sparking then it is an electrical problem... ignitor, ignition, coil issue. make sure your wires are seated and plugged into the coils firmly. if you see spark, then you may have a fuel flooding issue. try not to use so much choke... choke is not always necessary... I take it then this is a carbed bike?
MSchu is offline   Reply With Quote
Old 06-11-2007, 01:14 PM   #4
not2slo128's Avatar
Default Re: newbie w/ shadow 750 ACE starting problems (MSchu)
back to basics:
fuel
air
spark
fuel: You have wet plugs; you have fuel
air: duh
spark: this is most likely your problem. Check plugs/ignition system
not2slo128 is offline   Reply With Quote
Old 06-11-2007, 02:58 PM   #5
3Dcycle's Avatar
Default Re: newbie w/ shadow 750 ACE starting problems (not2slo128)
hey try to drain your float bowls. just cause it got gas dont mean it good gas.
3Dcycle is offline   Reply With Quote
only starts when push started (may not be starter or battery) machaux Honda Prelude 2 11-27-2016 02:55 PM
Nighthawk cb750 ignition/electrical weirdness sytheii Honda Motorcycles 2 07-01-2014 11:59 AM
1994 Acura Integra LS - Engine Dies, Power Stays On kirkouimet Acura Integra 3 09-04-2011 01:12 AM
Carburetor/Fuel System Troubleshooting (Honda F2) .Ash Honda Motorcycles 9 06-29-2007 05:50 PM
De-winterizing your bike tonydatyga Honda Motorcycles 16 03-12-2007 11:09 AM
Tags
2006, 750, ace, button, drain, engine, flooding, fuel, honda, ignition, plugs, problem, shadow, spark, start, starting, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
