Help w/ my little Honda XR70...shift lever problems
I got this XR70 little dirt bike to just play around on, and the damn shift lever seems unusually hard to downshift. When I get my foot under the shift lever to lift it to downshift from lets say 4th to 3rd, it seems really stiff. Is there an adjustment for this? It is a semi-automatic tranny, so it enables you to cycle through the gears, but it seems pretty tight when down shifting. Any help would be nice. Thanks
I know it's not a CBR or anything, but it's still a Honda. Help me out!
Re: Help w/ my little Honda XR70...shift lever problems (ScareyH22A)
Ya im letting off. I have ridden one of these before and it was a lot easier to down shift. I know there has to be some way to adjust it. I just need to know where and how
Re: Help w/ my little Honda XR70...shift lever problems (black7thgen)
The screw on the side case that has a nut to look it adjusts the clutch. When I put my clutch in my xr50 I had to adjust this because i was having trouble shifting it. Give that I try and see if it helps. I forget what whay you turn it to do what. You will just have to play with it.
Re: Help w/ my little Honda XR70...shift lever problems (boosted-delslow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted-delslow »</TD></TR><TR><TD CLASS="quote">The screw on the side case that has a nut to look it adjusts the clutch. When I put my clutch in my xr50 I had to adjust this because i was having trouble shifting it. Give that I try and see if it helps. I forget what whay you turn it to do what. You will just have to play with it.</TD></TR></TABLE>
That was it bro! I adjusted that screw and it shifts fine now. Thanks for the help guys.
Oh sorry 2003. It only has 3 gears...I just gave a 4th to 3rd example cuz im a retard. Don't know anything about these things, I just have fun riding them.
B18c1vicrx
08-10-2009 10:05 AM
