F3 600cc mini sprint transmission/clutch problem
I have a F3 Honda stock engine on a minisprint and have a problem with the clutch or transmission. The transmission has been modified with only lo gear, neutral and high gear with spacers replacing the other gears.
Problem is when I shifted from lo to hi, there was no high, nothing, a giant neutral. I check and realigned the shifter cam, which gave my gears back. When I shifted again the same thing happened.
Any thoughts or ideas?
