Cooling system pressure test - Honda-Tech
Old 03-18-2017, 11:28 AM   #1
lude98SH's Avatar
Default Cooling system pressure test
So I purchased a non-running 99 R6 as a project. Bike has poor compression 60 or so and poor leakdown results 40-75% leakage in all cylinders. I checked the valve lash and some of them are out, but not by a ton. I was reading that these years have issues with the blocks cracking, so before I went any further I did a cooling system pressure test and checked the oil.
Cooling system test: pressure drops about 1 psi within 5 minutes and then holds at 14 for several hours or more. No visable leaks. Will crank engine to see if I can find an issue. But is any pressure drop at all and indication of an issue or is this acceptable?
Engine oil: was fairing thin and free flowing, especially for it being like 30 degrees in the garage. It smelled strongly of fuel. Picture below. To be fair the bike has supposedly sat for like 2 years, so there could be some moisture in the oil as well.
lude98SH is offline   Reply With Quote
Old 03-20-2017, 06:35 AM   #2
lude98SH's Avatar
Default Re: Cooling system pressure test
So just an update. I did a crank test while pressurizing the system and it did not drop at all. Not coolant came out of the cylinders or anywhere else.
The oil was very thin and filled with fuel, not thick at all.
Summer A/C Guide, How it Works, and When it Doesn't slowcivic2k Tech / Misc 138 09-15-2016 09:52 AM
***High-Performance Cooling System*** hussain-vtec Forced Induction 114 01-31-2016 09:32 PM
What Typed of Oil? Answered. vtek9 Acura Integra 8 06-15-2011 11:33 PM
Coolant level fluxuating? ClubSiRacer Forced Induction 4 04-23-2003 12:08 PM
HAYABUSA TURBOCHARGED. QUARTER MILE IN 6.88 SEC (LONG........) Nikos Honda Motorcycles 14 02-20-2002 09:14 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
