CBR F4i HELP!
Old 07-07-2013, 09:30 AM
nveley22's Avatar
Default CBR F4i HELP!
Yesterday I was out for a ride and the bike started hopping and bucking on me. almost felt like it was running out of fuel but I just filled up. I stopped at a local motorcycle shop and I shut the bike off and then I could not get it started. I jumped it with another bike and it fired right up and ran fine. Is this just a bad battery? I know if the battery has bad cells then over time, it could cause the bike to not run right... No lights have ever came on the dash and it ran great after the bike was jumped and went all the way home. I put the battery on a tender and the battery is fully charged so according to the tender, the battery is ok. I am hoping its nothing too serious seeing that I just bought the bike. Any information would be great! thanks
Old 07-08-2013, 09:20 PM
GDD Member
slomofo's Avatar
Default Re: CBR F4i HELP!
Does the bike still have this problem? If so, run it down to autozone to have them check the output voltage of your battery which will determine whether or not your stator is bad.
Old 07-09-2013, 02:00 PM
r1turtleturtle's Avatar
Is it Carburetor? could have flooded it
Old 07-18-2013, 11:46 AM
Wahski's Avatar
F4i's don't have carbs.
Old 08-01-2013, 11:33 AM
Dylan2323's Avatar
my guess would be the starter. have you tried "push" starting it?
Old 08-14-2013, 05:49 PM
OrangeChrome's Avatar
Best answer I've seen so far. There is no carb. Fuel Injection ftw.
All signs point to battery/stator issue imo
Old 09-08-2013, 07:22 PM
bulwnkl's Avatar
Yes, likely a battery. The regulator/rectifier is a failure point on the F4 series (both carb'd F4 and injected F4i). Maybe on the F3 and/or earlier as well; IDK. Check cbrforum.com as well if this doesn't fix the issue.
Old 09-08-2013, 07:24 PM
bulwnkl's Avatar
Sorry for the double. Here's what that should have said:
There may be a battery problem, but the regulator/rectifier is a failure point on these bikes. Check both. (now read the rest of the post above)
Old 09-15-2013, 05:47 PM
Grape Ape Guy's Avatar
Charging systems are a pain....
verify battery is good and proper out put 13.6 ish to 14.4 ish volts
find out what internal resistance to rectifier is and measure with multimeter
find out what output the stator should put out and measure on bike with multimeter
I doubt this is a fi issue but if not in the charging system i would assume fuel pump
gsr-2nr
Honda Motorcycles
07-12-2008 06:04 PM
tvrsir
Honda Motorcycles
10
03-21-2006 01:34 PM
mookie
Honda Motorcycles
12
02-07-2006 01:33 PM
Boughetto
Honda Motorcycles
12
01-26-2005 01:12 PM
sshaikh01
Honda Motorcycles
07-02-2004 12:30 AM
Quick Reply: CBR F4i HELP!
