CB750 Valve timing - Honda-Tech
CB750 Valve timing
Old 05-17-2010, 11:23 AM   #1
Default CB750 Valve timing
I have been trying to sort out running problems on my 1981 CB750CB It was running badly spitting with odd backfire.It was also breaking down with wet plugs,The carbs on the bike were VB52C jetted P68 S75 They were butchered and only scrap I have tried a set on VB42A carbs with no improvement.I have replaced Ign coils,leads,and plug caps.Compression is from 120 to 150.On checking the valve timing I find that With the Dots on Cam chain sprockets lined up with the Cyl head the F mark is lined up not the T as in the Manual. Can I reposition timing by loosening Cam chain tensioners or do I have to loosen Camshafts.
pateli is offline   Reply With Quote
Old 05-17-2010, 11:38 AM   #2
Jasper_db1's Avatar
Default Re: CB750 Valve timing
Typically, all you need to do is pull the chain tensioner to loosen the chain enough to reposition the cams. Are you sure the crank is @ TDC when you checked the camshaft position?
Also, if it's an automatic type tensioner, remove it and reset it before reinstallation. Your manual should have the details.
Jasper_db1 is offline   Reply With Quote
Replacing Valve Seals on K24A1 in 2003 CRV zpinch K Series 7 04-27-2015 06:40 AM
The Trouble With Tribbles (oops, I mean Timing) querada Honda Accord (1990 - 2002) 2 10-24-2010 01:14 AM
CB750F DOHC FUEL DELIVERY PROBLEMS gravitywerx Honda Motorcycles 3 06-05-2010 08:03 PM
CB750 DOHC pateli Honda Motorcycles 3 05-15-2010 05:30 AM
Does anyone have the service pro. for timing chain??? help duffmanEP Acura RSX DC5 & Honda Civic EP3 0 04-30-2008 07:44 PM
Tags
1981, 750, adjust, backfire, cam, carb, cb, cb750, cb750k, honda, problems, set, timing, valve, vb42a
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
