04 Cbr 600 rr laid down wont start
Old 03-27-2005, 01:39 PM
JOJO0420's Avatar
Default 04 Cbr 600 rr laid down wont start
Is there a rest somewhere on the ecu or a breaker switch of some sort on the bike????
Old 03-27-2005, 01:56 PM
typeeg's Avatar
Default Re: 04 Cbr 600 rr laid down wont start (JOJO0420)
Try push starting it. After my R6 fell down I couldn't get it to start so that's what I did. After a nice ride it was fine.
Old 03-27-2005, 02:20 PM
JOJO0420's Avatar
it is not getting power
Old 03-27-2005, 02:47 PM
typeeg's Avatar
Default Re: (JOJO0420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOJO0420 &raquo;</TD></TR><TR><TD CLASS="quote">it is not getting power</TD></TR></TABLE>
explain?
Old 03-27-2005, 02:50 PM
hybridreams's Avatar
Default Re: (Reckless636)
try banging on the tail a little. if i remember correctly, there's a ball somewhere in there that tells the bike if it's on its side, and shuts the bike off if laid down. sometimes the ball gets stuck.
somebody back me up on this or tell me im crazy.
Old 03-27-2005, 03:05 PM
Grumpy Old Man
Veritas-Aequitas's Avatar
Default Re: (hybridreams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridreams &raquo;</TD></TR><TR><TD CLASS="quote">try banging on the tail a little. if i remember correctly, there's a ball somewhere in there that tells the bike if it's on its side, and shuts the bike off if laid down. sometimes the ball gets stuck.
somebody back me up on this or tell me im crazy.</TD></TR></TABLE>
You're not crazy, it's the tipover sensor.
When the bike leans to far to one side the circuit is completed and the bike shuts off. Not quite the ball rolling around in the tail that you make it out to be
They are usually in the tail of the bike somewhere
Maybe a 600rr owner will chime in on exactly where it is on your bike.
Old 03-27-2005, 03:16 PM
EG8R's Avatar
Default Re: (RebornGSR)
If you are talking about a "bank angle sensor" it located towards the front, maybe in the nose section? I don't know exactly where, sorry. Wire harness leads towards the rear...
Old 03-27-2005, 03:18 PM
JoshRambo's Avatar
Default Re: (skelly ed666)
Maybe a stupid question. But did you hit the kill switch when you laid it down?
Old 03-27-2005, 03:20 PM
Ag-Eng's Avatar
Take of side panel
Un-hook (-) of battery
Wait a minute
Re-connect battery
Turn RUN switch to "RUN"
Put bike in neutral
Put UP side stand
Pull clutch lever in
Press start button
VIOLA!! You're bike should start
Old 03-27-2005, 03:37 PM
hondab1015's Avatar
The bank angle sensor is in the upper that the front most part. I installed mine upside down when switching upper, prevented the bike from starting. I felt like a jackass once I figured it out.
Old 03-27-2005, 05:14 PM
ArmyGreenITR's Avatar
Default Re: 04 Cbr 600 rr laid down wont start (hondab1015)
Ive put my RR down twice an its started on the first try both times.Does it reset it self?
Old 03-27-2005, 05:16 PM
m.
m.'s Avatar
yea what reborn said, it's prolly your tip over switch aka fuel cut off causing your bike not to start back up. just wait a few mins the start her back up again. idk how hondas tip over are like but suzuki you would have to wait til the magnetic pendulum gets to its vertical position.
Old 03-27-2005, 09:21 PM
.Ash's Avatar
tilt sensor is in between the headlight lenses behind the upper. it is interesting you have this problem; a friend laid his 04 down and after a while, he held the throttle wide open and kept on cranking. started eventually... you can also bypass the tilt sensor for test purposes but if you can hear your fuel pump you are all set.
Old 03-28-2005, 10:55 AM
TurboDX's Avatar
Default Re: (usdmPC3)
well they say you learn something new everyday...thanks...i will need to know this for when it happens to me since there are only two riders...i have not been down but will keep trying not to...
Old 03-28-2005, 11:46 AM
Racer_XX's Avatar
is your bike in gear while you are trying to start it?
The GreenD16
Honda Motorcycles
96
09-16-2008 02:30 PM
884door
Honda Motorcycles
81
05-10-2006 09:31 AM
stockegsix
Honda Motorcycles
30
06-24-2004 06:17 AM
typeeg
Honda Motorcycles
09-25-2003 09:15 PM
Peepdis1024
Honda Motorcycles
18
04-24-2003 12:59 PM
Quick Reply: 04 Cbr 600 rr laid down wont start
