03-04 vs 05-06 CBR600rr plastic compatibility question?
Old 08-22-2006, 03:13 PM
Willybeen's Avatar
Default 03-04 vs 05-06 CBR600rr plastic compatibility question?
a friend of mine trashed his 600rr (2005) and another friend is converting his 2003 600rr so hes willing to sell all of his street stuff for a good price to the other friend... if he buys ALL of the fairings will they bolt up?
thanks...
if not are any of the parts the same? the sides? the tail? the upper? the headlight?
thanks
-william
Old 08-22-2006, 03:46 PM
Kusai.Nihonjin.Desu's Avatar
Default Re: 03-04 vs 05-06 CBR600rr plastic compatibility question? (Willybeen)
Better off going to 600rr.net. I doubt they'll bolt on, otherwise people wouldn't worry about findng '03-'04 or '05-'06 plastics for their particular bike.
Old 08-22-2006, 04:04 PM
Willybeen's Avatar
i cant get on 600rr.net... some movie attachment tries to start up
Old 08-22-2006, 04:09 PM
Default Re: (Willybeen)
Ahh..still having those problems. Not sure wtf is going on, it's done that numerous times before.
Old 08-22-2006, 05:54 PM
marmaladedad's Avatar
Same plastics.
Old 08-22-2006, 07:24 PM
99_SH's Avatar
The mids, lowers, and tank will fit fine. The tail and black triangle pieces underneath won't fit unless you change the subframe. The upper will fit if you swap the air ducts. The air duct covers are interchangeable I believe.
Old 08-22-2006, 08:28 PM
Willybeen's Avatar
Default Re: 03-04 vs 05-06 CBR600rr plastic compatibility question? (99_SH)
are you for sure?????? so if i take ALL of his body work the only thing that wont swap over is the tail unless he swaps the subframe??
Old 08-22-2006, 08:54 PM
Willybeen's Avatar
All parts off a 2003 CBR600RR
i have:
upper
right lower
left lower
headlight
right mid
left mid
ram air inlets
ram air covers
tail
front fender
Tank cover
passenger seat
passenger pegs
mirrors
side covers
those are the parts that i have off of an 03..... what will swap and what wont onto his 2005 600rr?
Old 08-23-2006, 09:42 AM
Willybeen's Avatar
anybody know?
Old 08-23-2006, 03:20 PM
LL2009's Avatar
the difference in fairings from an 600rr 03-04 and 05-06 is the front fairing and the rear cowl, the front will bolt on with no problem but you have to have everything thaT matches if is 03 front the windscreen, the air ducts, head lights, has to be 03, but if you want to put an 03 rear cowl on an 05 you need the entire sub frame with the font seat brake light and rear seat are the same....
Old 08-23-2006, 03:40 PM
Willybeen's Avatar
Default Re: (LLEO245)
awesome.. can anybody verify this or give me a link just to give piece of mind?
Old 08-23-2006, 04:07 PM
LL2009's Avatar
theres alot of info in 600rr.net but for some reason the site is down...
Old 08-23-2006, 04:26 PM
99_SH's Avatar
What is posted above is true. The only parts that won't swap are the tail & subcovers (unless you have the subframe) and front fender
Old 08-24-2006, 06:55 AM
.MilanoRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LLEO245 &raquo;</TD></TR><TR><TD CLASS="quote">the difference in fairings from an 600rr 03-04 and 05-06 is the front fairing and the rear cowl, the front will bolt on with no problem but you have to have everything thaT matches if is 03 front the windscreen, the air ducts, head lights, has to be 03, but if you want to put an 03 rear cowl on an 05 you need the entire sub frame with the font seat brake light and rear seat are the same....</TD></TR></TABLE>
What he said is true..
03-06 middle fairings are interchangable, the lowers are also interchangable but if you have a California bike, the 49 state lowers wont fit right. You can out California lowers on a 49 state bike with no problems though.
If you want to put the 05-06 Upper fairing on an 03-04 bike, you need the ram air ducts and windscreen to go along with it. I'm pretty sure the headlights are the same.. the 05+ tail wont fit the 03-04 subframe, so you have to swap that out along with the side covers.
Good luck
ruckusracer2010
Honda Ruckus and Scooters
15
05-10-2010 01:57 PM
SpoonSportsJunkie
Honda Fit
54
01-13-2008 10:40 AM
antoneexx
02-07-2007 10:48 AM
4dGSR at work
06-17-2002 07:20 PM
Quick Reply: 03-04 vs 05-06 CBR600rr plastic compatibility question?
