When to change replace Honda Fit transmission fluid - Honda-Tech
Old 10-08-2010, 04:30 PM   #1
gaydm.accord's Avatar
Default When to change replace Honda Fit transmission fluid
I went to Honda for a service recall on the driver side window a few months back and the service technician asked if I wanted to service my automatic transmission fluid. This is based strictly on mileage, before popping the hood, and before driving my car off for the original service. I asked the technician when the transmission service is supposed to be done. 20k he responds.
I declined, went home, and opened up my service repair manual. It says under heavy conditions I should replace my transmission fluid first at 60k and then every 30k after that. But I drive my Fit under normal conditions, just school and work. So I put the service off, now I am at 30k miles.
I decided to Google and find when I should replace my transmission fluid to no avail. So I call up Honda hoping I would get an accurate response this time over the phone. The person answering the phone was a female so I automatically discredited her.(JK) She says I should replace my A/T fluid at 15k and that I am way past due. I said blasphemy, the manual says otherwise. Now she backpedals and says that we recommend 15k for preventative maintenance, I just hung up on her. I didn't want to hear any other bogus information.
Does anyone have a Helms? I don't want to replace my transmission fluid if I do not need to replace it until 60k. I have the fluid I would rather not waste fluid if I have 30k more miles left. I don't mind replacing my fluids early in fact i usually replace my fluids a little early but 30 and 60 is too much of a difference.
I need facts not hearsay, any halp is greatly appreciated.
gaydm.accord is offline   Reply With Quote
Old 10-08-2010, 04:45 PM   #2
double11's Avatar
Default Re: When to change replace Honda Fit transmission fluid
The Helms states, under regular conditions the Automatic Transmission fluid should be changed at 60k mi. and then every 30k. pg. 3-8
HTH
double11 is offline   Reply With Quote
Old 10-08-2010, 04:56 PM   #3
Thank you, I called another dealership and they confirmed 60k then 30k. I guess this dealership has shady practices.
Honda World of Westminster
on Beach
Old 10-08-2010, 06:42 PM   #4
be professional
Targa250R's Avatar
Quote:
Not necessarily.
Honda as of late has been plagued by automatic transmission failures in many models. Since many Honda trannies do not have a replaceable ATF filter, and since Honda does not recommend power-flushing their automatic transmissions, changing the fluid on a more frequent basis than the specified interval is an inexpensive way to keep contaminants from building up and to keep the fluid fresh. Keep in mind that only about half of the total fluid capacity can be drained out of the case when changing the trans fluid; the rest remains inside the torque converter.
Heat kills transmission fluid, and heavy duty such as stop-and-go city driving and/or hauling a lot of people around will create a lot of heat in the trans. Independent testing has shown that ATF-Z1 does break down much more quickly than the specified service intervals would have you believe, and I've seen a number of transmissions develop problems even before the first service interval is due at 60,000.
Often you should just go by the book, but in some cases Honda gets it wrong. For example, Honda's original recommended service interval for the Dual Pump fluid in '97+ RealTime 4WD rear differentials was found to be far too long, as the fluid would often break down so quickly that the diff would start making growling noises while turning as early as 30,000 miles. Honda eventually revised the service interval for Dual Pump fluid to 30,000 miles, and then later to 12,000-15,000 miles for the first service on '07+ CR-Vs. Another example is valve adjustments - Honda specified a valve adjustment interval of 105,000 miles for B20 engines so that they could advertise "no tune-ups required until 105,000 miles." Many of these engines sustained damage to the cylinder heads due to tightening valve clearances before even reaching 105,000 miles.
For the record, I change the ATF in my personal vehicle every 20,000 miles. Depending on model, I recommend trans fluid change intervals anywhere from 15,000 (for '97-05 J-series, '97-01 H-series, '98-02 F-series, '01-03 D-series) to 30,000 miles ('88-00 and '04-05 D-series, '90-97 F-series, '92-96 H-series, all B-, C-, G-, K-, L-, and R-series). For CVTs, I recommend changing the CVT fluid every 15,000 miles for '96-00 Civic HX and every 30,000 miles for all other CVTs.
$25 worth of fluid once every 18-24 months is a lot cheaper than a $3000+ remanufactured transmission.
Targa250R is offline   Reply With Quote
Old 10-09-2010, 07:49 PM   #5
Thank you for that,
that was very informative.
Old 10-11-2010, 11:15 PM   #6
Ya its a very informative details that you guys have shared with us.thanks for telling us.
jack919 is offline   Reply With Quote
Old 10-14-2010, 04:42 PM   #7
99blackcivicSi's Avatar
your fit will bring up the minder for #3 about every 20k sometimes sooner sometimes later, but thats when i have been seeing them pop up
99blackcivicSi is offline   Reply With Quote
Old 03-25-2015, 06:14 PM   #8
miquel1955 is offline   Reply With Quote
2004 Accord EX Transmission Fluid (ATF) Change - Is it too late? j894 Honda Accord & Crosstour (2003 - Current) 9 01-21-2017 04:15 PM
back to Hondatech / 1 year ownership anniversary! Hatch Man Introduce Yourself 0 11-23-2016 08:56 AM
2000 Honda CRV - A/T gear hunting/flaring issue 3rd-4th gear farmersride Honda Element & CR-V 9 07-07-2016 07:36 AM
Used car experience 2006 CRV EJ8_Man Honda Element & CR-V 3 12-21-2015 09:15 PM
2012 Honda Accord V6 - Brake fluid bleed and change Sergey.R Honda Accord & Crosstour (2003 - Current) 5 06-23-2015 11:32 AM
Tags
2009, 30000, 98, auto, change, civic, cvt, fit, fluid, honda, hx, oil, replacement, time, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
